Kenodog
Posted: Mon Apr 21, 2014 1:14 pm Post subject: Piston / Rod removal question |
Hi guys I'm just in the process of rebuilding an engine but need the rods from my original which is still in the car. Is there any way to wrangle the oil pan around enough to get at the rod nuts and get them off ?
If this isn't possible does anyone have a spare set of good rods I could buy for a reasonable price ? (I need them pretty quick as I'm off to work in another province for 6 weeks and want to get this mess to the engine builder so it done by the time I get back.)
Thanks,
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
ThomasJoseph315 Guest
Posted: Mon Apr 21, 2014 1:33 pm Post subject: |
| I would assume not because how would you disconnect them from the piston? I would think the crankshaft would stop the piston from coming out from the bottom. Pull the head. |
Kenodog
Posted: Mon Apr 21, 2014 1:52 pm Post subject: |
Yes, I know they need to come out the top but can you actually access the rod nuts from the bottom in order to remove them and free the piston/rod assembly with pulling the block ? _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Mon Apr 21, 2014 4:27 pm Post subject: |
You can definitely get a wrench on all rod bolts with the block in the car. _________________ Toofah King Bad
Posted: Mon Apr 21, 2014 9:37 pm Post subject: |
| Kenodog wrote: | | Yes, I know they need to come out the top but can you actually access the rod nuts from the bottom in order to remove them and free the piston/rod assembly with pulling the block ? |
That's pretty much how it's done on most vehicles with oil pans |
Kenodog
Posted: Tue Apr 22, 2014 4:28 am Post subject: |
My inquiry was more about whether the oil pan can be removed with the block in-situ. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Tue Apr 22, 2014 5:12 am Post subject: |
To remove the oil pan, you have to drop the front cross member. I don't think you'd be able to shoe-horn it out of the way due to the oil pickup. The cross member drops easily be removing the four nylock nuts, the bolt/nut at the lower end of the intermediate steering shaft, and the four big bolts at the rear of the A-arms, so not really that hard.
I have plenty of matched sets of used rods if you need them. Cheap too, but shipping to Canada perhaps not so cheap, given the weight. _________________ erstwhile owner of just about every 924 variant ever made |
Kenodog
Posted: Tue Apr 22, 2014 2:28 pm Post subject: |
Sweet, just got it off. Dropped the cross member like you suggested Dan, good idea. Thanks for the help guys.
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Tue Apr 22, 2014 5:41 pm Post subject: |
| ideola wrote: | To remove the oil pan, you have to drop the front cross member. I don't think you'd be able to shoe-horn it out of the way due to the oil pickup. The cross member drops easily be removing the four nylock nuts, the bolt/nut at the lower end of the intermediate steering shaft, and the four big bolts at the rear of the A-arms, so not really that hard.
I have plenty of matched sets of used rods if you need them. Cheap too, but shipping to Canada perhaps not so cheap, given the weight. |
Dan,.. dumb question,.. and I know I can just walk out to the garage ans see this for myself, but the engine mounts,.. they aren't sitting on the cross member are they? You can drop the pan w/o bracing the engine? |
Posted: Tue Apr 22, 2014 10:34 pm Post subject: |
| ThomasJoseph315 wrote: | | Dan,.. dumb question,.. and I know I can just walk out to the garage ans see this for myself, but the engine mounts,.. they aren't sitting on the cross member are they? You can drop the pan w/o bracing the engine? |
You may be thinking of the 2.5L which does sit on the cross member. The 2.0L is suspended off of brackets along the frame spars. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Apr 23, 2014 3:17 pm Post subject: Re: Piston / Rod removal question |
| Kenodog wrote: | | If this isn't possible does anyone have a spare set of good rods I could buy for a reasonable price ? |
I got a spare set. _________________ 78 924 NA
5-lug |
Kenodog
Posted: Wed Apr 23, 2014 11:08 pm Post subject: |
I got them out but thanks for the offer !Tom. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Thu Apr 24, 2014 8:40 am Post subject: |
Went like milk & cake. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
