Posted: Thu Apr 10, 2014 6:02 am Post subject: Not head gasket? |
After a few weeks of not thinking about cars, I decided to pull the plugs on the CGT car for inspection. Looks like 1-3 plugs (L to R) are ok, but number four, hmmmm, a bit squished!! I heard a loud bang when the car died, and white smoke was pouring out the back end. Not sure cause/effect, chicken or egg, or whatever. Assuming plug is smashed, the valves are certainly not healthy either. I reused the rod bolts, but bought ARP nuts for them. I torqued those to oem specs, but, maybe that wasn't enough? They aren't as beefy as the oem nuts.
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Thu Apr 10, 2014 6:15 am Post subject: |
Ouch!! _________________ 80 Turbo - Slightly Modified |
Harm
Posted: Thu Apr 10, 2014 6:59 am Post subject: Re: Not head gasket? |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1424 Location: Washington DC area
Posted: Thu Apr 10, 2014 7:34 am Post subject: |
^ She looks like she's taking a dump. Like Dave's engine.  _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Thu Apr 10, 2014 8:03 am Post subject: |
Now that's funny! Reminds me of Patrick Swayze in 1991s Ghost. His acting 'ability' to me was reduced to thinking he had to take a 'crap' throughout the movie~!
Anyway, the engine does not turn over, so have to assume the worst. No biggy, have a Series II engine to rebuild. This one will be scavenged for parts. _________________ '83 944 Track car.
ThomasJoseph315 Guest
Posted: Thu Apr 10, 2014 11:26 am Post subject: |
| Plugs looked glazed,.. are those the standard temp plugs? |
Posted: Thu Apr 10, 2014 11:30 am Post subject: |
Maybe a broken valve is jammed between the piston and head. Did you try turning it backwards? _________________ White 87 924S "Ghost"
Posted: Thu Apr 10, 2014 12:06 pm Post subject: |
| I wanna see pics of this... |
Posted: Thu Apr 10, 2014 11:56 pm Post subject: |
It doesn't turn either way Paul; not sure if I'll pull the engine at the moment for carnage photos. _________________ '83 944 Track car.
Posted: Fri Apr 11, 2014 1:42 am Post subject: |
This is beginning to sound like a engine detonation
/me thinks about running colder plugs,... calls E3
https://www.youtube.com/watch?v=rTRy_pVtE1g
Last edited by ThomasJoseph315 on Fri Apr 11, 2014 4:33 am; edited 1 time in total |
Posted: Fri Apr 11, 2014 1:50 am Post subject: |
It's possible, however, I have quite a few track hours on that engine/plug combo platter. No 'specs' on the plugs either to indicate detonation. I removed more stuff off the engine yesterday, 75 degrees and all outside, so may get motivated in the next week and a half to remove it. _________________ '83 944 Track car.
Posted: Fri Apr 11, 2014 2:00 am Post subject: |
It's prolly just one of those things where this last race was the straw that broke the 924's back.
If you change your plugs heat index let me know how colder you go. I imagine you'd prolly go pretty cold cause of the turbo and your racing, at least I would. I am considering going one step colder in my engine for stock use being as it's a bbq out there in LA soon. |
9xx
Posted: Fri Apr 11, 2014 2:45 am Post subject: |
NGK B8EVX plugs are also very good for the 931 engine. _________________ Mikko
jason c
Dave, I would suggest tearing the engine down & finding the cause before you build the next engine so whatever the failure was can be prevented on the new engine. I would also suggest running the coldest plug that does the job. Are you looking at the plugs with the naked eye or with a spark plug scope?
The #4 was definitely physical damage, not heat.
Fyi, running "colder" plugs will not make your car run cooler. |
