TurboJak
Posted: Mon Jun 09, 2014 12:03 am Post subject: G31 2nd gear synchro issue |
I have replaced 2nd gear dogteeth and synchro but still have grinding when shifting into 2nd. Seems like the shift sleeve does not engage the synchro ring properly...
Anyone know if it is normal to have to replace the 2nd/3rd shift sleeve or do I have some other issue with the gearbox? _________________ ______________________________
'76 924 + '82 924T engine + GT look |
leadfoot
Posted: Fri Jun 13, 2014 7:38 pm Post subject: |
depends on how worn it was, sometimes you can get away with flipping it around but I replaced the shift sleeve, synchros and dog teeth...
carbon fiber GT mish mash
jason c
Posted: Mon Jun 16, 2014 7:06 pm Post subject: |
What type of trans do you have?
What condition are all the engagement teeth in?
Can you turn the synchro while its pressed on the cone?
Are the keys or keyways worn?
When the synchro, hub & gear are assembled, do the tips of the teeth line up or stay off to the side at their closest point? |
