jdub
Posted: Sun Mar 30, 2014 1:39 am Post subject: Hair wire Fuel Level Sending unit- anyone mod a float style |
i broke the hair-like wire inside the fuel level sending unit (top of tank) ,
(for some reason other types of porsches' are much more affordable to replace) $100+ i just don't have
i was gonna try to micro solder a new wire if i could fine that fine a wire, but, who know if it would work then in the end
is the hair wire supposed to gradually touch more on one side when it rises- look slike they touch the same the whole way up .
anyone have a trick they've done?
I've used a float type of unit in other cars which have 2 wires coming out, and was considering riggin one to the existing shell of the old unit, but the 3 wires on teh old one look like one is a significant ground, not just a normal ground. _________________ 81 924 non-turbo |
ThomasJoseph315 Guest
Posted: Sun Mar 30, 2014 1:51 am Post subject: |
I just took mine apart the other day for cleaning. I wouldn't see why you couldn't get a piece of wire the same gauge and solder it in. what's the worse that can happen? You have to buy a new one anyway? Make sure you check the resistances of the wires to match it though.
These guys got a lot of used parts...
http://www.partsheaven.com/ |
Ponz
Posted: Tue Apr 01, 2014 6:05 am Post subject: |
Don't open the unit. Pour somecleaning fluid in and shake it gently. Yes, the wires are very thin and prone to break. It might just be gummed up. _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
