datatrain
Joined: 15 Sep 2007 Posts: 441 Location: Osoyoos, British Columbia
Posted: Fri Feb 19, 2010 2:12 pm Post subject: Weaklings method to remove rear axle nut |
So I suddenly needed to remove the brake drum today. Haynes told me it would be tough. What's 140 lb guy to do ?
Buy a 36 mm axle nut socket 1/2 drive.
Borrow the wrench shown here.
This little honey is a 48" pipe wrench and must weigh at least 35 Lbs. Note the size of my shoe compared to the wrench.
Not shown.. a 200 Lb guy that jumped on it 4 times before it cracked.
After that it was simply a 200 lb guy with a 2lb hammer and 5 minutes of pounding on the drum.
Easy when you know how (or get lucky) and have a big guy handy. _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
Imafordguy
Posted: Fri Feb 19, 2010 2:35 pm Post subject: |
I only have a 24" pipe wrench... Good thing I have a 400 pound friend... Can I subsitute an 1/2# drive breaker bar for the pipe wrench??? _________________ 81 Porsche 924
84 Porsche 944(parting it)
66 Ford f100
66 AC cobra kit car(major project)
64 ford f100 (429 SCJ)
62 Studebaker golden hawk gt
61 baja bug (with bad opel 1.8, looking at ford 2.3 turbo to flovo) |
Posted: Fri Feb 19, 2010 2:53 pm Post subject: |
I use a six foot heavy steel pipe on the end of a 1/2" socket swivel. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
owenexile
Joined: 05 Jun 2009 Posts: 333 Location: Australia , Bunbury
Posted: Fri Feb 19, 2010 2:57 pm Post subject: |
Haha , Good job there !! Hopefull i wont have that problem im p.benching 160 kg  _________________ 924 1982 N/A
For some reason theres always a earth problem somewhere with this car... |
datatrain
Posted: Fri Feb 19, 2010 3:06 pm Post subject: |
Just to clarify, before I got this wrench I broke a Craftsman 1/2" bar with a pipe. It just snapped the end off. This was a last resort. _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
Imafordguy
Posted: Fri Feb 19, 2010 3:40 pm Post subject: |
| datatrain wrote: | | Just to clarify, before I got this wrench I broke a Craftsman 1/2" bar with a pipe. It just snapped the end off. This was a last resort. |
Ouch, bet that was a fun time. I will make a mental note to bust out the Impact for that.
The older they get... The more fun they are. _________________ 81 Porsche 924
66 Ford f100
Min
Posted: Fri Feb 19, 2010 4:52 pm Post subject: |
I had to use a impact rated 1000 ft-lbs of torque at 90psi cranked up to 125 psi to get the last one I did undone. I've lifted 924's right off the ground with a bar welded to a socket that I used to use. Fun fun.
rat
Joined: 02 Nov 2004 Posts: 92 Location: Colchester, Essex, UK
Posted: Sat Feb 20, 2010 5:07 am Post subject: |
Luckily there was a rural maintenace shop (tools for tractors) near me that had the 36mm socket with a big hole i could put a steel bar then an 8foot scafold pole on. Even then it required my 170lb dad and me with a hammer to get it loose on both sides :/
That is one manly pipe wrench there though! |
9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Sat Feb 20, 2010 5:11 am Post subject: |
I am 140lb and undone mine OK. Lift the car with a jack. Position the bar so that when you lower the car with the jack, the bar pusses against the ground and the weight of the car cracks the nut undone.
or just use the jack! (Shown here undoing wheel nut)
That was the easy bit, getting the drum off was the real nightmare. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
RC
Posted: Sat Feb 20, 2010 12:41 pm Post subject: Re: Weaklings method to remove rear axle nut |
| datatrain wrote: | | Buy a 36 mm axle nut socket 1/2 drive. |
NO, thats a big mistake.
After a collection of bent & broken handles, breaker bars and adapters realise it is best and cheaper to simply buy a 3/4" drive socket and bar the first time. Then add leverage/ pipe as required. |
CorsePerVita
Posted: Sat Feb 20, 2010 1:13 pm Post subject: |
I jumped on mine. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Harm
Posted: Sat Feb 20, 2010 7:13 pm Post subject: Re: Weaklings method to remove rear axle nut |
found footage
…I wouldn't use a Reversible Ratchet at first.
Start with a fixed socket or box wrench
and jump on that. |
924guy
Posted: Sun Feb 21, 2010 1:21 am Post subject: |
heres the tool you need....
 _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Sun Feb 21, 2010 2:22 pm Post subject: |
My impact gun has never had a problem with removing one of those. _________________ White 87 924S "Ghost"
ThomasJoseph315 Guest
Posted: Sun Mar 30, 2014 3:42 am Post subject: |
| I can honestly say I have never seen a pipe wrench and a socket used on an axle nut before,.. that cracked me up, lol. |
