ddharper2
Posted: Sat Mar 15, 2014 5:50 am Post subject: fuel pump works sometimes |
Is it possible to bypass the relay and run a bypass jumper off the key to the fuel pump? I realize that the relay will stop the pump in case of an accident and/or engine quits running. But, will it work,
Thanks Daryl |
edredas
Posted: Sun Mar 16, 2014 5:07 am Post subject: |
Yes, you can jumper the relay, however it is only recommended for testing purposes and must be removed once the engine is shutdown.
http://www.clarks-garage.com/pdf-manual/fuel-05.pdf _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
