Dtweth
Joined: 07 Mar 2014 Posts: 2 Location: Knoxville Tennessee
Posted: Sat Mar 08, 2014 6:54 am Post subject: Fuel injectors leaking on top of engine block + more.help? |
MY fuel Rail has a crack in it, thus im replacing it, as i was looking i also 2 of my fuel injectors leaking to the top of the engine block. how can i fix this?
Also my power steering Tension bar broke and the belt snapped along with the bolt that held it to the engine. How can i fix this? Also my right radiator fan is hitting my engine coolant hose, so i unplugged it how can i fix that? im thinking the shaking maybe from the engine or the motor mounts maybe need replacing?
1987 924s- Racing Yellow _________________ 1987 924s-silver |
gohim
Posted: Tue Mar 11, 2014 5:29 am Post subject: |
Yes, it definitely sounds like your car has a motor mount problem, and has had the problem for a while.
You might also check the condition of the balance shaft belt. Sounds like you have a vibration problem, which might have caused the cracked fuel rail as well.
The leaks at the fuel injectors are probably the result of the vibration, and old injector seals. Replace the injector seals when you replace the fuel rail. |
Posted: Tue Mar 11, 2014 10:20 am Post subject: |
You'll need new injectors. Hit up Pelican-Parts for those and new motor mounts to keep it from failing again.
Fuel rail, tension rod, etc. can come from an early 944 parts car, since they are the same under the hood as your car. Make sure they are in good shape before purchasing so you don't have to do it all again  _________________ Stefan
