rockhound72
Joined: 29 Oct 2012 Posts: 107 Location: Jacksonville, Arkansas
Posted: Sat Feb 15, 2014 1:47 pm Post subject: No more hot air |
| I believe the wire that connects from my dash switch to the heater valve broke or came off. I have tried to find the valve itself to open it since it has been a rough winter, but I can seem to get to the dang thing. Is there an easy way to get to it, and where exactly is it located. I've pulled the control switches out and it looks crazy. I'm not sure where exactly it came loose, but when I switch from cold to warm air, I don't hear the flap opening. I plan on some major restore work this year and a new sweet paint job, so little things first. Oh, this is my '79 toofah with the squirrel cage. |
Harm
Posted: Sat Feb 15, 2014 9:52 pm Post subject: Re: No more hot air |
After 30 years the heater valve can get kind a crusty;
mine was slowly leaking cooling fluid from the top
Easy fix under the hood, next to the firewall,
down between the oil pressure sender and WUR,
…if you're able to reach underneath/behind there,
above the clutch housing.
Quick fix:
Either recutting the (~bicycle) cabel might do,
or refitting the lever on the heater valve.
Lubricate the wire.
<_80_PET #477819017 Heater valve
>_80_PET#477819081 Heater valve
Take a look into PET for location and assambly…
http://www.924.org/parts/parts.htm on the subject:
| Quote: |
Heater valve. Standard VW part. $13.90. Listed in numerous catalogues for less than $20.
Note: late 82 and on uses 477 819 081. Difference not known to me. |
HTH
Kind regards,
