MikeDanger
Posted: Tue Jan 28, 2014 2:12 pm Post subject: Pressure valve O-ring size?? |
anyone know the Spec? _________________ It was either this or a giant box of legos |
Posted: Tue Jan 28, 2014 2:27 pm Post subject: |
There is a commonly available repair kit for the primary regulator that includes o-rings and a collection of shims for making adjustments... _________________ Toofah King Bad
MikeDanger
Posted: Tue Jan 28, 2014 2:31 pm Post subject: |
yes, but i want to pick it up locally, since there are 6 different parts stores down the st from me. _________________ It was either this or a giant box of legos |
Posted: Tue Jan 28, 2014 9:31 pm Post subject: |
The local parts stores are unlikely to have the correct metric size. I do not know what size it is. Why would you not purchase the correct kit? You do realize that you are risking spraying highly pressurized fuel all over your engine bay if the replacement o-ring doesn't fit correctly? Stop looking for short cuts and buy the correct part. _________________ erstwhile owner of just about every 924 variant ever made |
MikeDanger
Posted: Tue Jan 28, 2014 9:44 pm Post subject: |
the "kit" some Orings and washers? yeah thats going to be hard to find, better call across the country and have them ship me one tiny oring and washers, SO I have to quit working on this for a whole week.... thanks... _________________ It was either this or a giant box of legos |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Wed Jan 29, 2014 12:08 am Post subject: |
Bring old ones into FLAPS?
Harbor freight?
http://www.harborfreight.com/225-piece-metric-nitrile-o-ring-assortment-67609.html
If you're an Amazon prime member I'm sure they sell something you can use and it will be at your door in 2 days.
Keep in mind that this is high pressure. _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
Posted: Wed Jan 29, 2014 3:37 am Post subject: |
As I said, the local hardware is unlikely to have the correct metric o-ring in stock. If you want to waste your time driving around to 10 different stores searching in vain, knock yourself out. Even if you find something that fits, there's still no guarantee it will work correctly. I prefer to do things correctly the first time, and not risk blowing pressurized fuel all over my engine bay, but to each his own.
BTW, to spec it correctly, you need to factor in the following characteristics:
Inner diameter
Outer diameter
Cross-sectional profile
Cross-sectional diameter
Material (must be fuel safe)
"Squish" of the material when compressed to ensure proper sealing
Measuring the old one is not a good plan, as the original o-ring is quite likely to be far out of spec (why else would it need to be replaced). Since this part is not in the Porsche PET, there is no way to get those details from a known good source. So you can either guess your way through it and hope to get it right, or just purchase the damn repair kit that already has that particular O-ring and everything else you are likely to need to rebuild your fuel distributor.
By the way, from your previous post on the CIS test results, it appears that you have some fairly significant leak down on the the circuit, which is usually somewhere in the return line. You only correctly identified one potential culprit (the check valve). More often than not, that kind of pressure loss is caused by a leaking accumulator, which you would have known if you bothered to read the Haynes manual diagnostic section or the Probst source that I cited in my how-to. Or God forbid, done a search here on the forum.
Good luck. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jan 29, 2014 12:09 pm Post subject: |
And if you think faulty o-rings are no big deal, tell that to NASA. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jan 29, 2014 4:39 pm Post subject: |
Should have gone for the legos. _________________ Toofah King Bad
Joined: 05 Jun 2006 Posts: 1489 Location: Ontario, Canada
Posted: Wed Jan 29, 2014 7:51 pm Post subject: |
| Rasta Monsta wrote: | | Should have gone for the legos. |
 _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
MikeDanger
Posted: Thu Jan 30, 2014 5:20 pm Post subject: |
| ideola wrote: | As I said, the local hardware is unlikely to have the correct metric o-ring in stock. If you want to waste your time driving around to 10 different stores searching in vain, knock yourself out. Even if you find something that fits, there's still no guarantee it will work correctly. I prefer to do things correctly the first time, and not risk blowing pressurized fuel all over my engine bay, but to each his own.
Inner diameter
Outer diameter
Good luck. |
its a 7mm ID/2mm cross section
carried at advance auto parts, OR your local seal/oring supply.
I figured Id try the easy to get to $0.50 part first.... _________________ It was either this or a giant box of legos |
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Fri Jan 31, 2014 5:27 am Post subject: |
There is a smaller one on the tip. _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
