dubrict
Joined: 22 Apr 2011 Posts: 150 Location: Horseheads NY
Posted: Mon May 13, 2013 10:06 am Post subject: Has anybody tried flex seal on their battery tray? |
This is the stuff that's advertised on TV to seal leaky gutters and things of that sort. It's rubber in a spray can.
I'm not one to look for a quick fix, but if it works as advertised then it sounds perfect for this job _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
Posted: Mon May 13, 2013 11:15 am Post subject: |
that would probably work. Depends on the extent of your damage, small holes below the battery area, or the inner fender wall is rotted. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Mon May 13, 2013 11:23 pm Post subject: |
I used spray rubber on top of the aluminum plate I riveted in. it worked well, and it's still sealed after e years.
I'm pretty sure the stuff they advertise on TV is regular spray rubber, but it carries a hefty price tag. _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1422 Location: Washington DC area
Posted: Tue May 14, 2013 4:17 am Post subject: |
Whatever floats your boat ...  _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Clbmkr1
Joined: 21 Jul 2010 Posts: 76 Location: Wind Point, Wi.
Posted: Wed May 22, 2013 4:20 am Post subject: |
I had a small crack in the original metal that leaked severely. I used Rust-Oleum Leak Seal on it and its been fine for almost a year now. _________________ Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape |
dubrict
Posted: Mon Mar 31, 2014 7:37 am Post subject: |
I attempted this repair today using rustoleum leak seal. I don't think it will hold up, at least not the way I did it! I found out the hole was quite a bit larger than I thought so I grabbed a slice of gasket material, covered the hole and blasted leak seal all over the place. It was the best solution I had on hand.
Soon I will have to just cut it all out and weld a new tray in place _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
Posted: Tue Apr 01, 2014 8:28 am Post subject: |
I use seam sealer, comes in a tub and paint on with a brush.
Thicker than my wife's gravy or wheel bearing grease. _________________ Porsche 924 1984 (UK import) NA
