tscharke
Joined: 29 Oct 2013 Posts: 30 Location: Adelaide, Australia
Posted: Thu Oct 31, 2013 10:27 am Post subject: Thermofan |
I've noticed my 924 doesn't like to sit in traffic or typical 35+ adelaide days as the temp gauge rises on its way to the red. I am intending on putting the thermo fan that was connected the to a/s system that I stripped but have a few newbie questions:
1. Do i need to have a relay set up? do they draw that much current
2. If there any where I can fit it to a thermo swtich? that is conseridering they have one in stock version
3. Or should I just wire it straight to an on/off switch on the dash
Cheers in anticipation
Cheers
Scott _________________ 1981 Porsche 924 2.0 NA |
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Thu Oct 31, 2013 12:42 pm Post subject: |
Both 924's that I have purchased have come with thermo fans? Regardless, your AC fan should help. You can buy a kit from repco that has a sensor that gets slipped into the top radiator hose where it joins the radiator. This comes with a little box and an adjustment for the fan on and off. From memory they are about $70??
Otherwise I think the radiator should have a place for a fan switch, just get a 90 - 95 odd degree one and wire it through a relay _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Lefty
Joined: 14 Oct 2013 Posts: 61 Location: Sydney, Australia
Posted: Thu Mar 13, 2014 7:24 pm Post subject: |
Guys, I had my 924 for five years and admit I'm a slow learner.
I notice the car is getting hooter this year.
I had the sensor in the radiator replaced a few years ago and they put one in from a higher ranger,
I have flushed the radiator and installed a lower temp thermostat.
Also am ramming the car with the ac on on hot days to keep the fans running all of the time.
I'm thin kings of getting the radiator recored as the recent collant change produced some rusty metal in the fluid. I'm hoping the recore and the low temp sensor will resolve the issues.
Cheers lefty _________________ One less beige car |
txjake
Joined: 17 Feb 2007 Posts: 395 Location: Oklahoma City OK
