Svobodin
Posted: Fri Nov 01, 2013 6:32 am Post subject: Help removing broken fuel bolt from injector |
I snapped the head off one of the fuel injector bolts off inside the injector, and its stuck pretty good. Any tips on getting it out? Drilling it out? I don't really want to replace the one injector right now, and I don't have enough in the repair budget to replace all 4 right now without sacrificing something else. Suggestions?
Posted: Fri Nov 01, 2013 7:00 am Post subject: |
Sit tight, someone should have a few of these gathering dust. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Svobodin
Posted: Fri Nov 01, 2013 7:14 am Post subject: |
| That would be much nicer than paying thru the nose for a new one... I'm going to try making a groove with a dremel to try to take it out with a screw. |
Posted: Fri Nov 01, 2013 7:34 am Post subject: |
Soak in PB Blaster or home made penetrant for a day or two. Carefully apply a bit of heat and I bet it comes right out. _________________ Toofah King Bad
