Putting her back together
Bryan M
PostPosted: Mon Oct 28, 2013 10:58 pm    Post subject: Putting her back together Reply with quote
In the final stretch after paint. Can't find the pics, so I could use some help.
Need pics of the window trim where the aluminum strip and the rubber seal attach.
I'll probably have others to add.
Also, is the rubber body seal behind the fuel filler tube NLA?
(For a '79)
'69 912
'79 924
larchie
PostPosted: Thu Oct 31, 2013 4:10 pm    Post subject: Reply with quote
I don't have images, but I hate to see a post hanging. Maybe the following comments will spur someone more knowledgeable to reply.
If you are asking how the seal and trim can be put back together, the following might be helpful. It's been too many years since I've done this, but I think much of this description of installing the quarter-window of a 928 would apply; other varied tips are here for installing the molding.
I think you are describing the either the U-shaped gasket (28A in the diagram below)in front of the plastic cover of the filler neck PN 477201351 gasket which is available, or you might be describing the O-shaped gasket (24 in the diagram below) PN 477201557 gasket around the filler neck which has been changed to PN 94420155300.
Both are listed as available at AutoAtlanta so it seems likely they are available elsewhere. The O-shaped gasket 19 in the diagram doesn't seem to be available since it's not listed.
Fuel Tank Parts
Bryan M
PostPosted: Thu Oct 31, 2013 9:10 pm    Post subject: Reply with quote
Thanks for the reply.
I'm referring to the door window. There's an aluminum strip and a rubber scraper.
And the fuel filler tube seal is #19. It's the body seal around the gas cap. The tube comes out and it goes between the body and the flange of the filler tube.
'69 912
'79 924
larchie
PostPosted: Sat Nov 02, 2013 2:39 am    Post subject: Reply with quote
Part 19 in the diagram is Porsche Part 477 201 317 FILLER NECK GASKET and was available until one or two years ago. World Impex says they still might be able to locate it. It's also listed as available at Rector Porsche or Rector Motors, but I doubt that since that links appear to be a front for Factory Mopar Parts.
