Scorpio
Posted: Wed Oct 23, 2013 6:43 pm Post subject: Rear engine water |
As soon as the engine starts should I be seeing water flowing straight out of the smaller rear engine pipe when unhooked (connects to smaller outlet on coolant transfer pipe) I unhooked the pipe to check and nothing .... Does it only flow when it hits temp? I wouldn't think so _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
gerben1986
Joined: 13 Mar 2008 Posts: 232 Location: The Netherlands
Posted: Thu Oct 24, 2013 12:29 am Post subject: |
The themostat is opening based on temperature, so that means that when the engine temperature is getting higher, the flow is starting slowly.
So indeed, only when the engine is warming up the flow is starting. _________________ 911SC - 1980 |
Scorpio
Posted: Thu Oct 24, 2013 6:33 am Post subject: |
But shouldn't water pressure within the engine block itself be high due to water circulating from the water pump all the time? Thus forcing water out the rear flange? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Scorpio
Posted: Thu Oct 24, 2013 6:34 am Post subject: |
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Scorpio
Posted: Thu Oct 24, 2013 6:35 am Post subject: |
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Scorpio
Posted: Thu Oct 24, 2013 6:36 am Post subject: |
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Scorpio
Posted: Thu Oct 24, 2013 6:37 am Post subject: |
I see how that works with flow to the radiator......But shouldn't water pressure within the engine block itself be high due to water circulating from the water pump all the time? Thus forcing water out the rear flange? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Thu Oct 24, 2013 7:45 am Post subject: |
from all the info I have gathered it should flow around the engine until it warms up. then it opens the line to the radiator. _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Oct 24, 2013 7:50 am Post subject: |
Posted: Thu Oct 24, 2013 7:57 am Post subject: |
Water should flow around the engine until the thermostat opens to the radiator _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Oct 24, 2013 8:02 am Post subject: |
Posted: Thu Oct 24, 2013 8:05 am Post subject: |
Posted: Thu Oct 24, 2013 8:10 am Post subject: |
Posted: Thu Oct 24, 2013 8:15 am Post subject: |
