Performance Hesitation
fwish21
PostPosted: Mon Sep 23, 2013 11:07 am    Post subject: Performance Hesitation Reply with quote
Well...I bought a 1980 924 NA for my son and I to work on. The body and under carriage are in great shape. Has 125K on it. One issue that I have is that the car does not accelerate smoothly. Starts up fine whether it is hot or cold. I do plan on replacing the inexpensive things first (plugs, wires, cap, rotor and air cleaner system). After doing some research the two things that stick out out are the Bosch Ignition Module and the Cold / Warm regulator. Again, it does not have a problem starting when it is cold or hot so I am kinda ruling out the regulator. My guess is the ignition module might be an issue. Does this sound right and is there an alternative to spending $400 on a new Bosch unit? Thanks for listening.
1980 924 NA
5-speed
nickthompson
PostPosted: Mon Sep 23, 2013 11:35 am    Post subject: Reply with quote
Check for vacuum leaks. MSD igition works great .
fwish21
PostPosted: Mon Sep 23, 2013 12:10 pm    Post subject: Reply with quote
Thanks! the MSD ignition was one of the options i came across. Thinking of it. vac leaks is one of the first things I will go after. Thanks again.
PostPosted: Mon Sep 23, 2013 2:45 pm    Post subject: Reply with quote
Don't forget to check the throttle body shafts for leaks as well. Luckily you can adapt similar throttle bodies from Audi's and VW's of similar timeframe, but they aren't rebuild able unfortunately.
PostPosted: Tue Sep 24, 2013 8:16 am    Post subject: Reply with quote
Ignition unit is very unlikely to be bad. Will repeat advice I gave another newb today:
1. Smoke intake
2. Repair all vacuum leaks
3. Check system and control pressures, hot and cold
4. If needed, correct system pressure via shim adjustment to primary relief valve, correct control pressure via WUR refresh
5. Set mixture
Ian89C4
PostPosted: Thu Sep 26, 2013 12:04 pm    Post subject: Reply with quote
do you have the lambda system on your '80? Look for an O2 sensor on the exhaust and an injector looking thing hanging off the side of the air plenum (thing with the fuel distributor on it).
If you have this system you may have other issues of too much fuel being let back into the return to the tank, you may also have the issue of not enough fuel being returned to the tank.
Checking the fuel system pressures will allow you rule that out a fuel dizzy issue, the lambda issues are harder to diagnose.
Do you have a haynes manual?
Like the advice says above, check the easy stuff: plugs, vacuum leaks, old tired coil, old plug wires....etc....
Don't rule out the ignition module, I had one go out on me a little while ago, but the car will just not start, not run rough...but it could be a symptom.
Keep us updated.
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
fwish21
PostPosted: Tue Oct 08, 2013 11:16 am    Post subject: Reply with quote
Thanks for the comments. I just put the car away for the Winter (Live outside of Buffalo, NY) and will tackle this in the Spring. Bought this as a project for me and my son to take on. He is 13 and autistic so I am trying to find something he may like to do. I come from the world of Alfa Romeos and loved the 924 since it came out, but could never afford one when I was a kid. Well...enough of that. Have already bought plugs, wires, Lindsey Racing vacuum hose kit, radiator hoses, cap and rotor and other cheap goodies. Going to tackle this in the Spring. Will keep you up to date. Just a little update. While driving it to its place of storage it just stutters during acceleration. Cruises okay, but acceleration is the issue. No over-heating issues either. Everything seems to work. I'm still thinking it's a vacuum leak, but you never know. I will keep in touch. Thanks!
