fwood
Joined: 26 Apr 2010 Posts: 40 Location: Yadkinville,NC
Posted: Sun Sep 22, 2013 9:48 am Post subject: Transmission shift rod |
I recently resurrected my 82 931 after 3 months of work. Turned out that a wire in the back of the fuse panel had worn the plastic off and caused a short that fried the DITC. Thanks Ideola for the working box. I only looked at the fuse panel when play driving my dead horse and tried the turn signals which did not work. Seems that the DITC shares the "circuit on with ignition #15". Fixed the short the turn signals worked but it took a different DITC to regain spark! Okay I digress-as the inspection had lapsed I took my first road trip to my friendly inspect station. While driving back(passed of course) I noticed shifting problems. At first I was ready to call and pontificate profusely at the kid who did the inspection about thrashing the gearbox and screwing it up. long story shortened I decided to pull the shift rod out of the transaxel and discovered that the springs inside had rusted apart.(the car had sat for at least 10 years outside when I bought it). What I need now is either the springs or a new (working)shift rod #016 331 475 G. I am also in need of 016 311 735 A and 016 311 717 C the spring and bushing as the spring was nonexsting and the bushing is rough.crusing the net it seems that all these pieces are no longer availeable so im asking for a little help!
Thanks Frank |
fwood
Posted: Sun Oct 20, 2013 1:58 am Post subject: |
Found a nos shift rod and what a difference. The car has never shifted so smooth and easy. It is absolutly the single most impactful part that I have installed on the car.
Frank |
