Aftermarket oil coolers
ThomasJoseph315
Guest
PostPosted: Sun Jun 30, 2013 6:47 pm    Post subject: Aftermarket oil coolers Reply with quote
I found this page and was wondering if I needed a external oil pump for this.
http://www.automotion.com/1977+porsche+924.html?cat=1861
PostPosted: Mon Jul 01, 2013 10:23 pm    Post subject: Reply with quote
Nope.
Ian89C4
PostPosted: Wed Jul 03, 2013 11:14 am    Post subject: Reply with quote
Not unless the car is doing only track work.
With ambient track temp the last time I was out at 120, my oil got upwards of 250*F.
Regular driving conditions will (should) not drive it that high.
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
ThomasJoseph315
Guest
PostPosted: Wed Jul 03, 2013 5:07 pm    Post subject: Reply with quote
I want my oil as cool as possible. I been known to gas it from time to time... meaning,.. every weekend
PostPosted: Wed Jul 03, 2013 8:40 pm    Post subject: Reply with quote
Why would you want it as cool as possible, that will only cause wear on the engine and high consumption. Its better to have correct temperature(and viscosity), hence the thermostat on the standard oil cooling system.
I have driven a stock 125Hp car on track for many years without problem (looong stints aswell). If you aint running a tuned car or track car there is little to no point in doing this. Buy some quality oil instead. Especially if you have a us engine with less than 125 HP.
daniel
PostPosted: Fri Jul 05, 2013 8:21 am    Post subject: Reply with quote
Why not fit an oil temp gauge first so you know whats going on.
Also I have found with these motors that high oil temps go with high water temps, so if water is ok dont worry
1989 944 Cabriolet
kcoyle
PostPosted: Sat Aug 03, 2013 11:17 pm    Post subject: Reply with quote
If you are hell bent on an oil cooler check out B&M super coolers. They are relatively cheap. I had one on my turbo'd miata years ago. Keep in mind the price creeps up when you start adding in extra bits like AN fittings, adapter plate, oil filter relocation,thermostat, etc.
