About the dizzy
ThomasJoseph315
Guest
PostPosted: Tue Jul 23, 2013 3:34 am    Post subject: About the dizzy Reply with quote
I noticed there are extra bolt holes that the dizzy can be rotated a bit more. I'm thinkin if I unbolt the dizzy housing and rotate it a bit the thing wont be hitting the hood as much or anymore, thus maybe I won't be getting this bucking.
This sound a bout right? will this throw anything out of wack?
scm924s
PostPosted: Tue Jul 23, 2013 4:32 am    Post subject: Reply with quote
Why should it hit the hood in any position? Moving it will upset the timing.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
PostPosted: Tue Jul 23, 2013 4:41 am    Post subject: Reply with quote
The distributor housing has two sets of bolt holes, such that it can be oriented in two different positions. If it is installed in the incorrect orientation, the cap will hit the hood. So if your cap is hitting the hood, you need to take all three bolts out of the housing, rotate it slightly to the lower (correct position). It would not be surprising if the wires are misfiring if the cap or wires are in contact with the hood.
The above photo shows the correct orientation of the distributor housing. Note that the bolts should be installed in the right-most of each of the pairs of bolt holes. If yours is installed with the bolts in the left-most holes, the cap will be oriented too high and will likely interfere with the hood as you describe.
scm924s
PostPosted: Tue Jul 23, 2013 5:13 am    Post subject: Reply with quote
Ah, all is clear, correcting this shouldn't affect the timing.
1977 Martini - sold
Fifty50Plus
PostPosted: Tue Jul 23, 2013 11:23 am    Post subject: Reply with quote
Right most = clockwisiest
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
ThomasJoseph315
Guest
PostPosted: Tue Jul 23, 2013 12:17 pm    Post subject: Reply with quote
This is exactly what I am talking about,.. thanks for the heads up!
...heads to the garage... and yes I think I am getting a misfire issue..
I think the previous owner's name was Sum Ting Wong.
ThomasJoseph315
Guest
PostPosted: Tue Jul 23, 2013 5:13 pm    Post subject: Reply with quote
Update: I no longer Miss-fire! Woot! Thanks!
Btw,.. what engine is that? Your spark plugs seem to be on the wrong side.
PostPosted: Wed Jul 24, 2013 7:04 am    Post subject: Reply with quote
That is a pic of the DProd tribute motor I am building. It has a 931 head, which is why the spark plug holes are on the intake side. More details about that build here: http://www.924board.org/viewtopic.php?t=36293
