Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Sun Mar 18, 2012 7:54 am Post subject: how can you remove the clutch and brake pedal? |
It is unclear to me if and how the clutch and brake pedal can be removed.
Can somebody explain?
Duncan _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
CorsePerVita
Posted: Sun Mar 18, 2012 9:39 am Post subject: Re: how can you remove the clutch and brake pedal? |
| Duncan wrote: | It is unclear to me if and how the clutch and brake pedal can be removed.
Duncan |
I think with the dash and everything in the way it'd be kind of a pain. My car has no interior so it's easier for me.
But basically there's a clip on the end of the rod where the brake pedal is, that comes off. The rod can then slide towards the clutch pedal and out. Be careful removing them as the bushings that hold the pedals in are a plastic, I am not sure how easy or hard it would be to find them if they break.
The rod can slide out on the clutch side but it'll be tight. Also, use something to lubricate it when you put them back in. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Duncan
Posted: Sun Mar 18, 2012 6:33 pm Post subject: |
Thank you!
I will take out the seat to get more easy access.
I already have new plastic bushings, which are still available from the dealer at relatively little cost.
AppleBit
Joined: 16 Nov 2002 Posts: 1516 Location: Minneapolis, MN
