For the unwary
PostPosted: Thu Aug 01, 2013 11:19 am    Post subject: For the unwary Reply with quote
I have been plagued with bad running ever since I replaced the head gasket in April.
I replaced most ignition bits, double checked valve and ign timing, adjusted the A/F mix using a gas tester, checked for ign leaks and basically went over all the obvious stuff. Check fuel flow etc.
Had some improvement after replacing the coil and dissy cap.
Still had a miss at idle, bad misfire under medium and hard acceleration and stalling.
While checking the TIU as part of the Haynes manual checks, for some reason I checked the earth from the TIU to the battery. High resistance. This should be zero.
Cleaned up where the TIU mounts on the body and now purrs like a kitten.
SORTED!!
PostPosted: Thu Aug 01, 2013 3:21 pm    Post subject: Reply with quote
OK, IB. WTF is TIU?
PostPosted: Thu Aug 01, 2013 3:27 pm    Post subject: Reply with quote
Transistorized Ignition Unit.
DOCO
PostPosted: Thu Aug 01, 2013 10:54 pm    Post subject: Reply with quote
Grounds grounds grounds so important. They are even more important now with all computerised fuel injection and computerised transmissions.This is one of the biggest issues with diagnostics in the late cars. Everyone forgets the grounds!!!
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
PostPosted: Fri Aug 02, 2013 7:15 am    Post subject: Reply with quote
By habit I check my multimeter every time I turn it on.
I had one lead on the -ve and touched what should have been a good ground. (body of TIU). When I got nothing I had a WTF followed by an AHA! moment.
PostPosted: Thu Aug 15, 2013 8:16 pm    Post subject: Reply with quote
Didn't last long.
Bad running returned.
Think I found the culprit this time. The new rotor button has zero resistance.
the book of lies says it should be about 5k so tested the old one and refitted it. at 4.8k it seemed good enough.
runs a lot better so now looking for another new rotor.
will test run again tomorrow.
PostPosted: Fri Aug 16, 2013 12:25 am    Post subject: Reply with quote
No pics
PostPosted: Sat Aug 17, 2013 7:55 am    Post subject: Reply with quote
Two days now, no misfires, runs and pulls well.
do you want pics of a rotor?
sbarc
PostPosted: Sun Aug 18, 2013 5:22 am    Post subject: Reply with quote
I would love to see a photo showing the location of the "Transistorized Ignition Unit"....so I can check my own car.
Anyone have any idea where this unit is?
1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT
PostPosted: Sun Aug 18, 2013 7:37 am    Post subject: Reply with quote
Behind the driver's headlight on the front of the inner fender. Small silver box about the size of a pack of cigarettes.
PostPosted: Sun Aug 18, 2013 10:58 am    Post subject: Reply with quote
Yep check those grounds, this is a 924S main engine ground point:
