Snail shell fill plug?
CorsePerVita
PostPosted: Tue Jul 09, 2013 3:35 am    Post subject: Snail shell fill plug? Reply with quote
I have several allen sockets, and even have one that fits. However, the fill plug appears to be on the passenger side hiding between the transmission mounts? Is that correct? If so, what is the procedure for getting that damn thing out?
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Tue Jul 09, 2013 5:14 am    Post subject: Reply with quote
Place jack under transaxle, lift slightly, remove offending mount, remove fill plug, lift transaxle enough to fill with fluid.
Reinstall plug, lower transaxle, reinstall mount.
CorsePerVita
PostPosted: Tue Jul 09, 2013 6:01 am    Post subject: Reply with quote
Was hoping I was missing something or that I wouldn't have to do that. *sigh* ok.
- 1999 Ducati 900SS
PostPosted: Wed Jul 10, 2013 6:45 am    Post subject: Reply with quote
If you have one of these:
...you can use a cutoff wheel to cut off about half of the Allen key. You can still use the socket as normal, and then you can use the part that you cut off with a 17mm wrench to get that one fill plug out without having to remove the tranny mount.
PostPosted: Wed Jul 10, 2013 3:18 pm    Post subject: Reply with quote
I need to look at mine, I don't recall removing anything but the plug. Maybe short arm allen key?
