Lella control arm bushing problem.
PostPosted: Sun May 27, 2012 12:07 am    Post subject: Lella control arm bushing problem. Reply with quote
Finally getting around to installing the Delrin control arm bushings from the group buy. My rear bushings are NOT holed all the way thru, think I'm a bit 'short' for the bracket and bolts to line up. Did I get the wrong ones? Or, are we suppose to drill these out? (I have a problem with this, finding the correct drill bit, and then, not enlarging the existing hole) Or, they should work fine as-is?
PostPosted: Sun May 27, 2012 3:20 am    Post subject: Reply with quote
Ah, never mind, forgot I have this nice floor drill press I never use. Used a 3/4" wood bit, and it cut like butter. The last 1/4" of material shouldn't make a difference if it's a bit over-sized. If it does, I'll let you know~!
PostPosted: Mon Jun 24, 2013 3:18 pm    Post subject: Reply with quote
Perhaps a call to the vendor?
PostPosted: Mon Jun 24, 2013 5:28 pm    Post subject: Re: Lella control arm bushing problem. Reply with quote
I didnt buy delrin bushings, i have powerflex bushings and mine were the same.
I drilled them out too.
daniel
PostPosted: Tue Jun 25, 2013 8:57 am    Post subject: Reply with quote
I understand that we are NOT supposed to drill them out, mine are installed that way and are working just fine
1989 944 Cabriolet
