McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Sat Jun 22, 2013 6:34 pm Post subject: 931 Rear stud replace |
How to do this? I had some shorter studs and stock 21mm spacer doesn't fit so I need longer studs (70mm?) What should be done to replace them? I need to replace them on rear only to get back to stock specification with 21mm spacer  _________________ 931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
Posted: Sat Jun 22, 2013 9:33 pm Post subject: |
You pretty much have to remove the hub to do this. Might as well refresh the rear bearings while you're at it. _________________ erstwhile owner of just about every 924 variant ever made |
