Removing pin through geatbox?
frankg
PostPosted: Mon Jun 10, 2013 5:45 am    Post subject: Removing pin through geatbox? Reply with quote
Was taking out the engine and gearbox of a 931 I have when we found the pin through the clutch/bell housing solid and will not budge. Put screw in to try and pull etc without any luck,
so anyone any bright ideas on this?
Life is about living, we all leave soon enough.
PostPosted: Mon Jun 10, 2013 7:08 am    Post subject: Reply with quote
You're talking about the shaft for the release bearing fork? There is a 'set-screw' on the backside that holds it in place; did you loosen that? There is a 'window' on the driver side of the housing. Take a screwdriver or something similar and drive out the rod from that end. Shine a light down there first to get an idea of the setup, there is a protruded aluminum (aluminium) 'stop' for the shaft when inserting it.
frankg
PostPosted: Mon Jun 10, 2013 7:47 pm    Post subject: Reply with quote
A Grenadier your a genius !! Well more a genius than my brother although to be fair I did forget the manual but he has had enough experience of these cars and others to know that - guess so should I but I believed him when he said it just pushed in and nothing else !!
Just saves a clutch that would otherwise have been destined for the skip !!
