oscillating idle S1
pcelenta
PostPosted: Tue Jun 25, 2013 5:17 am    Post subject: oscillating idle S1 Reply with quote
changed most of the vacuum hoses on the 1980 s1 I picked up. car runs well...but did notice that it has a bit of an oscillating idle when warm. was thinking leaky injectors or bad injector pattern...leaky cold start valve. any thoughts?
PostPosted: Tue Jun 25, 2013 10:34 am    Post subject: Reply with quote
Don't forget leaking throttle body shafts.
PostPosted: Tue Jun 25, 2013 5:45 pm    Post subject: Reply with quote
Don't discount an air leak issue completely which will affect idle and if only a small leak will not be noticed when driving. TB and idle screw O rings? All vacuum hoses and elbows?
pcelenta
PostPosted: Wed Jun 26, 2013 1:56 am    Post subject: Reply with quote
thanks guys. I think there are a couple of hoses I missed...and I certainly didn't think of those tiny o-rings at the throttle body. More work to do! will have to wait as I get #99 turbo to the media blaster and then body shop. check out my updates on that car in another post.
