fuel pump not working 931 - 1981 + image
Dutch924-racer
PostPosted: Thu Jun 06, 2013 3:47 am    Post subject: fuel pump not working 931 - 1981 + image Reply with quote
My car was a good running and driving car. Ik took out the wiring loom for painting. Today I built it back but the fuel pump doesn't run.
See image:
relais connection 30: gets 12v
relais connection 15: gets 12v switched
the green wire to the coil is tested and good
I can't find the problem. The car sparks so I asume the DITC stuff is all good. I have two fuel pump relais who worked before, so that can't be the problem. The fuel pump was also just new.
maybe the green-white wire to relais connection 1 is the problem, where should it go to ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Thu Jun 06, 2013 4:50 am    Post subject: Reply with quote
What about the overboost cutoff switch? I would eliminate it as a variable, and ground it out for now. If it is disconnected or the wire is broken where you can't see it, it cuts power to the fuel pump circuit.
Also, have you jumper the fuel pump relay to verify that the pump is running?
Dutch924-racer
PostPosted: Sun Jun 09, 2013 4:07 am    Post subject: Reply with quote
Thanks Idealo, problem is solved.
You can geuss to problem :
937 trackday car
Series 2 engine
Fast road camshaft
