Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Wed Jun 05, 2013 4:20 am Post subject: Adjusting brake pedal and clutch ? |
I am reassembling my pedals in my 931 (1979).
I see you can adjust the brake pedal and clutch, I lost my settings.
Does it matter how you set them ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Posted: Wed Jun 05, 2013 11:23 am Post subject: |
Yes.
Both master cylinders must top out, or else they won't be able to self-adjust, and can result in the clutch never fully engaging or the brakes from never fully disengaging.
You'll be able to find definitive adjustment procedures with searching, or in manuals. _________________ 78 924 NA
5-lug |
Posted: Wed Jun 05, 2013 4:06 pm Post subject: |
| !tom wrote: | | Yes. . .find definitive adjustment procedures with searching, or in manuals. |
My, how !helpful.
Adjust clutch to result in 2-3 mm free play at the pedal (distance until actuating lever touches the piston in the master cylinder).
Brake pedal actuating rod is much less finicky. Only rule is, if you have it too tight, the brakes will drag. I have mine adjusted so that the brake pedal, when depressed, lines up with the throttle pedal for heel toe purposes. _________________ Toofah King Bad
joewest
Joined: 06 Oct 2005 Posts: 234 Location: Portland, OR
Posted: Thu Jun 06, 2013 12:37 am Post subject: |
| Quote: | | I have mine adjusted so that the brake pedal, when depressed, lines up with the throttle pedal for heel toe purposes. |
Like a Bauwss  _________________ '79 924 Supercharged / Track Prepared
'80 931 Daily Driver - Sold
"The number of posts in my profile may represent the number of times I have screwed something up...and admitted it here." |
Posted: Thu Jun 06, 2013 12:45 am Post subject: |
The instructions for the hydraulic clutch are not in Haynes or the normal 924 FSM. They are only in the Turbo-specific (Vol 5) FSM.
 _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Jun 06, 2013 3:53 pm Post subject: |
And 2.5 FSM. . .
