creeves84
Posted: Wed May 29, 2013 10:10 pm Post subject: Spark issue |
I need help- I have a 82 base 924 that was not running when I bought it. I found the dist. was bad, so I rebuilt it with a kit. I have spark from the coil but not to the cylinders. Can it be the igintion module?
I had spark at one time after the rebuid so I believe it to be rebuilt properly. It had weak spark after and I had the timing set wrong but ran, just very poorly so during the process to correct the timing I found no spark past the coil. I replaced the rotor and the cap already.
Any ideas on where to look? |
Posted: Thu May 30, 2013 9:49 am Post subject: |
The spark at the coil says the ignition system is working but the dissy is not distributing to the plugs.
check the rotor is turning and the plugs and ignition timing is correct and leads are in the correct order. _________________ Porsche 924 1984 (UK import) NA
Ian89C4
Posted: Thu May 30, 2013 11:44 am Post subject: |
I was having that same problem and it was my Ignition Control Module. _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Thu May 30, 2013 9:46 pm Post subject: |
Do you have spark at the coil?
NO? It could be the sensor in the dissy or the ign module. _________________ Porsche 924 1984 (UK import) NA
creeves84
Posted: Thu May 30, 2013 10:49 pm Post subject: |
Thanks guys- I checked the rotor and it is turning, verifed the plug wires at least 10 times (really hoping this be the case) and also checked TDC and made sure everything was all lined up.
I think it is the module also now that I have a cooler head...and will replace that, I will let the group know what I find out. |
creeves84
Posted: Sun Jun 02, 2013 10:05 pm Post subject: |
| Ian89C4 wrote: | | I was having that same problem and it was my Ignition Control Module. |
I ordered a module as everything else checks out, I will let the group know what I find out as soon as it comes in. |
