Wiper "paddle" control in the field of view for th
ditch68
PostPosted: Wed May 08, 2013 5:21 am    Post subject: Wiper "paddle" control in the field of view for th Reply with quote
That is where mine is in the "off" position all the way up. (1979 924).
Just seems odd that it would be there and not out of the way when off? Is something not put together correctly??
Jeff
Current:
1979 924, all stock.
1988 951 all track modded out and angry.
Past: 1986 951, 1988 924S, 1965 912 with '69 911T engine.
staticsan
PostPosted: Wed May 08, 2013 12:32 pm    Post subject: Reply with quote
That doesn't sound right. On my '82, the "top most" (most anti-clockwise) position is full speed, followed by half-speed, then off, then intermittent.
Wade.
'82 British NA - Which I think I've been very lucky with!
scriblz7
PostPosted: Thu May 09, 2013 2:39 pm    Post subject: Reply with quote
all the way up is full speed on my 79
Riley
79 924 n/a with gt body
15 VW GTI
PostPosted: Fri May 10, 2013 10:29 am    Post subject: Reply with quote
Top speed not working? Do you have 2 speeds?
ditch68
PostPosted: Fri May 10, 2013 11:38 am    Post subject: Reply with quote
I just checked it again a few minutes ago (to make sure I wasnt nuts), and yes - all speedz work, just in backwards order. As I recall, the plug is curved like the steering column on the switch end. Maybe it is reversed at its termination. Is that at a fuse block?
Jeff
Current:
ditch68
PostPosted: Fri May 10, 2013 12:10 pm    Post subject: Reply with quote
Uhhh. This dpes not look good. Checked the plug at the end of the column, that can only go one way.
Is there supposed to be white cloth tape on every wire bundle going to the ba k of the under dash fuse block? I fear (maybe I am being paranoid) that someone replaced the fuse block and spliced everything correctly...except that.
If so I guess it is not the end of the world. Would explain this, though.
Will dig further and report back.
Keff
Current:
