Ponz
Posted: Fri May 10, 2013 6:31 am Post subject: Idles and then will die |
My 931 will start normally and run but will not idle. If I stop for a light it will stall. I pulled the plugs and they are almost new looking and I have had them
in for years.
I am suspecting my fuel pump or fuel filter.
Any Ideas.
vince _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
Posted: Sat May 11, 2013 2:26 am Post subject: |
Strange, I was just talking to a guy yesterday who had the exact same problem on another kind of car (jeep). Car would start, run at speed, but when he came to a light, it wouldn't idle and stalled.
Turned out the negative battery cable was corroded inside the casing and wasn't providing a good ground. Looked ok on the outside but was all rusted out inside.
So, its a silly thing to check but stick a jumper cable from the (-) terminal to the block and see if it cures the problem. |
Ponz
Posted: Sat May 11, 2013 7:23 am Post subject: |
Thanks for your help.
I just had the car painted Forest Green Metallic and I have not been able to drive it far.
I will use your method.
I personally think it is the fuel pump or the fuel filter. I pulled and cleaned the plugs and they are light tan and too clean therefore I suspect the above.
I need help with this one. Anybody?
thanks again,
79 931 Euro
87 911 Targa |
joemac
Posted: Sat May 11, 2013 10:10 am Post subject: |
Check for leaking injector seals. _________________ Race car: my favourite palindrome.
Porsche: my favourite race car. |
Posted: Sat May 11, 2013 11:10 am Post subject: |
Try a new filter and install it in the correct direction. _________________ White 87 924S "Ghost"
Ian89C4
Posted: Sat May 11, 2013 11:19 am Post subject: |
I would think that if it was the fuel pump or fuel filter being clogged it would have issues at all speeds and would actually get worse the more load (going faster) that you put on the system.
Check the connections to your idle switch (one of the two on the bottom of the throttle body and IIRC the one on the top as well) to ensure that they are not corroded and the wires have not frayed. Also ensure that you hear a 'click' from all of the switches as you open and close the throttle body.
+1 on checking for vacuum leaks and the negative to the battery.
I would also try checking to see if the coil is pushing enough juice to the dizzy.
Don't know if any of this will help, but just stuff I would try.
Good luck!
Ian _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
leadfoot
Posted: Sun May 12, 2013 10:13 am Post subject: |
how old is the ignition switch too, when this wears it cuts out the motor too...
check you AAV isn't gummed up,
you could try opening up the air bypass on the throttle and run a slightly higher idle, this may help you diagnose the air or fuel problem... if it still stalls then it's most likely fuel... if it doesn't stall then it's most likely air...
stu _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
Ponz
Posted: Mon May 13, 2013 1:06 am Post subject: |
It starts then after a little while it wants to die. It will run okay but lift off the throttle and it will die. I think it is a fuel problem. I pulled the plugs and they were too clean. Light tan.
I will check the fuel pump and filter first.
thanks all
79 931 Euro
87 911 Targa |
Ponz
Posted: Tue May 14, 2013 3:58 am Post subject: |
I drained the gas tank and the gas came out clean. No rust or dirt.
Replaced with new gas same problem.
I will try to replace the fuel pump and see what happens. At over 200 dollars it seems steep.
79 931 Euro
87 911 Targa |
Posted: Tue May 14, 2013 4:03 am Post subject: |
Things happen with the lights off, and car in garage! However, try opening up the air screw on the throttle body and see if it idles. Also, the piston on the fuel distributor might be gummed up and not moving correctly. Check fuel pressure as well, and pull the FPR on the side, see if it's varnished. Do this before replacing the 'spensive pump. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Ponz
Posted: Tue May 14, 2013 10:04 am Post subject: |
Thanks everyone.
I will try the suggestions. I will probably ask again. Sorry to say this but I don't work on engines. I leave to the experts. I really appreciate the help.
When I lived in NY I had a guy who worked for a Porsche tuner and then he now has his own shop. He is in NY and out of range. He charged next to nothing. I walked him through an adoption as I have two boys who are adopted. I believe my NY friend used him also.
I don't like paying $100 an hour unless I have to. Sad I know but I worked long hours running my business and never got into the engine work.
thanks for your patience _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
Ponz
Posted: Tue May 14, 2013 10:09 am Post subject: |
I reread my post............sorry Paul Celenta I did not mention your name. _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
