924 distributor question about timing?!?!?! HELP
Karpaazio
PostPosted: Fri May 03, 2013 5:31 pm    Post subject: 924 distributor question about timing?!?!?! HELP Reply with quote
So I started thinking about does the N/A distributor change timing with overpressure, normally there is vacuum but in my case my 924 N/A is turboed so does the timing adjust work anymore on overpressure? and is there a difference in late 931 distributor to N/A?
Porsche 924 1978 Cabrió:
http://www.garaget.org/?car=219790
Porsche 924 widebody (next up?)
Toyota Crown LS110 1983:
http://www.garaget.org/?car=260537
Audi a6 2.7tt quattro 2000 daily driver
leadfoot
PostPosted: Fri May 03, 2013 6:20 pm    Post subject: Reply with quote
N/A has mechanical and vacuum advance,
once you hit boost there would be no advance from the distributor, you would want to retard the ignition if anything...
stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Karpaazio
PostPosted: Fri May 03, 2013 6:28 pm    Post subject: Reply with quote
Thank you stu!
But am I able to retard it enough just by adjusting the distributor?
leadfoot
PostPosted: Sat May 04, 2013 10:46 am    Post subject: Reply with quote
That will retard the whole ignition curve and mess with the entire powerband and idle...
IIRC the early 931 used a vacuum and boost adjustment on the distributor before they went to DITC. Keep in mind the ignition curve is set for a different combustion compression ratio and shape, it may work but i would plot the mecanical and v/b curves and see if thats what your after.
Stu
