j03k64
Joined: 26 Jul 2010 Posts: 123 Location: Urbana, Ohio
Posted: Fri Mar 15, 2013 7:20 am Post subject: A Fuel Pump - Wiring and Alternatives |
I picked up a second car at an auction a while ago. Trying to get it to run cheaply, but reliably. The fuel pump is dead for sure and I have a couple simple questions!
1) Does anyone know the specifications on the fuel pump for an 1980 924 (N/A CIS)? Pressure/volume/flow/voltage/ECT
2) Are there alternatives to buying the Porsche pump at $194? EG: A cheap way to replace it?
3) Wiring. I've got a black/green striped cable and a pinkish cable for wiring. Which is positive and negative? (the one on my car has been replaced in the past and the haynes manual's diagrams are insanely confusing).
Cheers! _________________ 1979 Porsche 924
1980 Porsche 924 |
the_mad_electrician
Posted: Fri Mar 15, 2013 11:17 am Post subject: |
Each of these questions easily answered by using the forum's SEARCH feature. _________________ Toofah King Bad
j03k64
Posted: Fri Mar 15, 2013 12:22 pm Post subject: |
Thanks Mad! That is definitely the correct one!
I've been here since 2000, previous account got murdered while I was overseas due to inactivity. SEARCH is only as good as the subject lines, which frankly suck. In fact, this thread is in the top 5 results. _________________ 1979 Porsche 924
1980 Porsche 924 |
Posted: Fri Mar 15, 2013 12:36 pm Post subject: |
Input "fuel pump alternative" and check the box labelled "search for all terms." _________________ Toofah King Bad
j03k64
Posted: Tue Apr 30, 2013 1:47 am Post subject: |
The Walbro 604 pump flow side banjo fitting does not fit the fuel line on either of my cars (a 1979 and a 1980). However, the Walbro 608 pump appears to include both fittings.
Dan and I are working to sort this out and will let you guys shortly! _________________ 1979 Porsche 924
1980 Porsche 924 |
