Changing Vacuum Lines
Mudd
PostPosted: Tue Apr 30, 2013 6:23 am    Post subject: Changing Vacuum Lines Reply with quote
I have a 1978 924 na. Can I change all of the existing original vacuum lines with the red silicon lines from Lindsey. I am asking this question because most of the existing vacuum lines have the cloth covering and look larger than the simple new vacuum lines.
1987 944
ditch68
PostPosted: Tue Apr 30, 2013 7:06 am    Post subject: Reply with quote
Call them and discuss, I believe the sets they have are designed for 944 use, but they stock a huge array of silicon lines for every 944 application, and they will have what you need. The inside diameter is all that matters in this case,
I have had repeated excellent customer service experiences with them, and would not hesitate to say they will do you right. Great company IMHO.
They stock everything you will need, and work with you.
Good Luck!
Jeff
Current:
1979 924, all stock.
1988 951 all track modded out and angry.
Past: 1986 951, 1988 924S, 1965 912 with '69 911T engine.
