Gas Tank Gasket
MikeJinCO
PostPosted: Sun Apr 28, 2013 10:10 am    Post subject: Gas Tank Gasket Reply with quote
I need to take the bottom plate off the gas tank and clean the strainer. I checked with Sunset Porsche and of course the gaskets are NLA(it is a '77). Permatex makes a sealant called Motoseal that is gas resistant or I could get some rubber gasket material from McMaster-Carr. Has anyone been thru this? Suggestions for gasket material?
Mike
'67 MG Midget Dp
PostPosted: Sun Apr 28, 2013 10:38 am    Post subject: Reply with quote
I have gasket material in bulk, and plan to cut one out for my leaky tank. I'll let you know if it works!
scm924s
PostPosted: Mon Apr 29, 2013 5:15 pm    Post subject: Reply with quote
I would be interested to find out whether these bolts come out without shearing off, before I try mine
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
PostPosted: Mon Apr 29, 2013 9:53 pm    Post subject: Reply with quote
There are no bolts at the bottom of the tank. Just a big fitting for the hose. You might be referring to the bolts on the top?
scm924s
PostPosted: Mon Apr 29, 2013 10:48 pm    Post subject: Reply with quote
The early tanks have a circular removeable plate on the bottom, which, presumably, covers a screen!
1977 Martini - sold
MikeJinCO
PostPosted: Mon Apr 29, 2013 10:58 pm    Post subject: Reply with quote
Yes, mine has a plate with 5 or 6 bolts to the bottom of the tank, supposedly it covers a filter screen. Bolt heads are maybe 8mm so probably 4 mm bolts. I got some Motoseal and will try to remove it gently today. Last thing I need is bolts broken off down there.
Mike
'67 MG Midget Dp
nickthompson
PostPosted: Mon Apr 29, 2013 11:09 pm    Post subject: Reply with quote
My 77 also had bolts on the bottom.
MikeJinCO
PostPosted: Tue Apr 30, 2013 10:09 am    Post subject: Reply with quote
Removed the plate today. The gasket was in reusable condition so after cleaning the plate of some minor rust type debris with a wire brush, I reassembled with Motoseal on both sides of the gasket and on the bolts. There should be some very snug plastic(maybe nylon) washers on the bolts to get a seal. Mine had one with an oversize copper crush ring and one with nothing. It had appeared to be seeping. There is only a pickup tube inside the tank, no filter screen. This is a car without an internal pump and a right angle screen filter between the tank and pump. Now letting it sit overnight to cure.
Mike
'67 MG Midget Dp
scm924s
PostPosted: Tue Apr 30, 2013 4:03 pm    Post subject: Reply with quote
Interesting, wonder why the plate then if no internal filter?
1977 Martini - sold
