autobahnkid
Posted: Sun Apr 07, 2013 2:23 am Post subject: Torque Tube Bearing Location |
The first bearing at the front od the Torque Tube (engine side) is less than an inch from the flange. Is this the right location for it. Has it creeped forward?
http://www.flickr.com/photos/94673538@N05/8625239084/in/photostream
 _________________ 1980 924 N/A "the beast' |
Posted: Sun Apr 07, 2013 3:35 am Post subject: |
Highly doubtful that it moved. If it did move a tiny bit, not worth worrying about, IMO. _________________ Toofah King Bad
autobahnkid
Posted: Sun Apr 07, 2013 10:35 am Post subject: |
Thank you. Better certain than sorry. _________________ 1980 924 N/A "the beast' |
autobahnkid
Posted: Sun Apr 07, 2013 11:16 am Post subject: Flex plate bolt torque value |
I cannot seem to find in Haynes nor the shop manual the torque value for the four bolts that hold the flex (drive) plate assembly to the torque tube on an Automatic.
Help  _________________ 1980 924 N/A "the beast' |
McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Mon Apr 08, 2013 12:23 pm Post subject: |
Try check this in Porsche Technical Specification...
"Porsche_924_Tech_Specs.pdf" you can find it here: http://db.tt/xn7w3MpG _________________ 931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
autobahnkid
Posted: Mon Apr 08, 2013 11:42 pm Post subject: |
Thank you McYver, Wonderfull information. _________________ 1980 924 N/A "the beast' |
