77 924 backfires
manostihl
PostPosted: Mon Apr 01, 2013 3:07 am    Post subject: 77 924 backfires Reply with quote
I found out I was lining up the wrong dot on the cam , so I reset the cam timing and the dizzy was 180 off so I pulled it and reset it on #1. Tried to start it and it still only backfires. Could there be something wrong with the ignition box? Its a 77 Porsche 924 NA for those who don't know.I couldn't find my old thread for some reason
I don't have an attitude problem you're just an asshole!
DOCO
PostPosted: Tue Apr 02, 2013 11:07 pm    Post subject: Reply with quote
When you reindexed the cam belt,did you redo the wiring order.Bring up the #1 piston to top dead center (compresion stroke)and then pop off the dist cap and look at where the rotor is pointing. If the rotor is correct check the wiring and make sure its wired in the correct direction the dist.rotor turns.
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
Ponz
PostPosted: Tue Apr 02, 2013 11:45 pm    Post subject: Reply with quote
check for holes in the exhaust system.
77 1/2 track car
79 931 Euro
87 911 Targa
