914 deal or no deal
rockhound72
PostPosted: Sat Mar 30, 2013 1:08 am    Post subject: 914 deal or no deal Reply with quote
I just found a 914, I think it was a '71, the guy wants $1900 OBO. First I laughed loudly since my toofah was $1500. Secondly ALL the car needs redone. All exterior rubber, paint, has no bumpers, door handles, dash in bad shape. Basically a major re-do. are these 1.8L cars worth it? I thought it would make an awesome roadster with the right engine. My own little Porsche/ Cobra. The seats looked good at least. I figured $300 tops. I have seen restored models go for up to $20,000. What is the pro opinion out there? If anyone is interested, I will get pics 4 u. It is in Little Rock, Ar.
nickthompson
PostPosted: Sat Mar 30, 2013 1:15 am    Post subject: Reply with quote
The amount of rust and where the rust is at is an important factor to consider in the purchase of a 914. Do a little internet research and your find where to look.
PostPosted: Sat Mar 30, 2013 1:25 am    Post subject: Reply with quote
I think it really depends on your capabilities and how much work you want to do. For someone with the time, money and energy to do a full resto, it might be a decent deal. But if you have any financial constraints, walk away. It's not an investment, and you will NOT make money on it.
PostPosted: Sat Mar 30, 2013 1:53 am    Post subject: Reply with quote
The body is by far the most important thing when looking for a 914. Rusty rockers, corrosion under the battery.
MikesCoupeGT
PostPosted: Sat Mar 30, 2013 3:24 am    Post subject: Reply with quote
If this is a 1971, then it is either a 2.0 liter or 1.7. The early 1.7 litre engines had more hp than the later 1.8 and breathed easier than the later cars due to smog addons. That being said, make sure that the body, and rockers (in and out) are in good shape.
When I restored my 914 I had to replace the inner and outer rocker panels. Not a fun job and they need to be solid, because that takes the stress when the roof is not on!
For 1900 I might walk away. If it is solid in the rockers and the battery tray is not falling off, check the rear suspension pickup points.
The 914 is a go-cart, they handle really well and are a great car to drive. Just be sure, much like the 924 to check it all over.
Just my two cents.
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sat Mar 30, 2013 9:38 am    Post subject: Reply with quote
Even down here in rust-free Arizona, the cars listed as rust free command a high dollar. Your decision rests on whether you want to add a different platform to what you already have. I have a similar situation, as do others. I have both a sickness for the 924 and my air-cooled 911. I'd add a rust free 914 to the mix, down here only, if I was done working on the other two, three, four, etc. So, do you really want to add to your fleet with a different kind of car with different attributes and associated problems? The 914, has it's own community, forums, parts sources, etc., than the 924. The eye of the beholder can fool you.
CorsePerVita
PostPosted: Sat Mar 30, 2013 10:04 am    Post subject: Re: 914 deal or no deal Reply with quote
Nope. #### no even. For what it'll cost you to put that car in "nice shape" you can go find a nice 914 for $5-6k.
A NICE paint job will set you back anywhere from $4000 to $6000 depending on prep work, paint quality, rust repair and potentially even more if you want "concours style". Reupholstering the interior is easily $$$ to $$$$.
I found mine for $6500 with original dash, interior, wheels, paint and even though it's got door dings and the usual wear and tear it is a nice car and extremely original. There's no way I'd spend $1900 on a 914 that needs a new paint job, panels, body parts, interior work, etc.
It is much much easier to start with a nice example if you want a nice end result, than it is to start with a pile of rot and work your way up.
If you're dead set on it be sure to check rust areas:
- Battery area
- Trunk and storage areas
- Frame areas (jack inserts especially)
- Near the master cyl/wall area
- Floorpan
- Rockers (should be removed and inspected, they are NOTORIOUS for serious rust issues and easily hide rust if the exterior of them look nice).
If that all checks out and it's good, it might be a good candidate for a resto IF you want to spend that kind of money. Otherwise, keep searching for a nice example and start there.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
Raceboy
PostPosted: Sun Mar 31, 2013 6:27 pm    Post subject: Re: 914 deal or no deal Reply with quote
I know I would Because just there isn't much to choose from here and in Europe they ask cosmic amounts for 914's.
Would put the nice 2.4liter 911 engine there with hi-comp pistons and S cams, would make a very nice ride!
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
CorsePerVita
PostPosted: Sun Mar 31, 2013 11:00 pm    Post subject: Re: 914 deal or no deal Reply with quote
They're a dime a dozen here in the shape he is describing. If they are that crazy in price there, no doubt you could find a nice one for cheap, ship it over, and probably be cheaper than the others there
I always forget that other places don't necessarily have an abundance of them.
Do we have automatic word filtering here? If not, then whoever censored my post, sorry for the language. I try not to let it slip but it happens now and then. I'll be more mindful next time.
- 1999 Ducati 900SS
