PanamaCarrera
Joined: 13 Mar 2012 Posts: 81 Location: Southport, UK
Posted: Sun Apr 28, 2013 2:12 am Post subject: H-E-L-P !! Cam Belt Pulley Removal |
Help!
How the **** do you remove the cam belt pulley from the cam shaft?
I tried trying to lock it with an extension bar from a socket set but reached a point where I was using so much force I was worried I'd damage the top of the cylinder head.
Anybody got any magic tricks or suggestions?
Thanks
(Posted on 931 Tech too, but maybe ther's an n/a owner who knows how) _________________ Nigel Walker |
joemac
Posted: Mon Apr 29, 2013 11:08 am Post subject: |
With the sprocket flexed outward, and the bolt loosely inserted, rap the head of the bolt with the BFH. _________________ Race car: my favourite palindrome.
Porsche: my favourite race car. |
Ian89C4
Posted: Mon Apr 29, 2013 11:23 am Post subject: |
Get a butane or propane torch and heat the bolt up until it is cherry read (or there abouts). Be careful not to melt the seal, but I take it you are replacing that anyways. The heat will cause the bolt to expand a little, but it may help to free any bits that are corroded within the threads.
After that, get a short extension bar and hook it up to your socket. Then get a a shop hammer and give it a few good smacks (the extension that is). It will turn the cam, but it will be jerking the bolt loose as well. Be aware that it may take a few good smacks. If it takes too long, reheat the bolt and go back at it.
Have patience so that you don't brake anything. Ask me how I know....
I would disconnect the negative lead on the battery so that she does not try to start as the cam goes around...
Good luck _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
joemac
Posted: Mon Apr 29, 2013 12:14 pm Post subject: |
Perhaps I've misinterpreted and the bolt is still in there?
If so, by all means, whack it once with a good solid blow of the BFH.
Also works on those pesky wheel bolts. _________________ Race car: my favourite palindrome.
Posted: Tue Apr 30, 2013 2:45 am Post subject: |
1) remove the cam
2) Stick a breaker or pry bar into one of the holes in the pulley.
3) Stand on the bar
4) Put a wrench on the pulley bolt
5) Bounce on one or both until the bolt comes loose... |
