New Injectors
ThomasJoseph315
Guest
PostPosted: Fri Jul 12, 2013 6:32 am    Post subject: New Injectors Reply with quote
I have this style on my 76 (77 on title). Anyone know if these are the right parts number for this?
http://www.oreillyauto.com/site/c/detail/BOS0/0437502023/02521.oap?year=1977&make=Audi&model=100%2BSeries&vi=1007008&ck=Search_C2368_1007008_-1&pt=C2368&ppt=C0024
I had to look up an Audi 100 series to get this one.
PostPosted: Fri Jul 12, 2013 2:57 pm    Post subject: Reply with quote
Bosch # 047 133 551, Fuel Injector.
ThomasJoseph315
Guest
PostPosted: Fri Jul 12, 2013 6:21 pm    Post subject: Reply with quote
Can sell 4 for $202 shipped.
Those new?
ThomasJoseph315
Guest
PostPosted: Sat Jul 13, 2013 3:50 am    Post subject: Reply with quote
Anyone know what CC's of fuel over x time these injectors need to be putting out?
ThomasJoseph315
Guest
PostPosted: Sat Jul 13, 2013 4:51 am    Post subject: Reply with quote
Can someone confirm this,.. I think I have the wrong injectors in my car. I mean I don't know if they make a difference with the a/f trim, but this is what is installed in my car.
These are for a 1977 Volkswagen Scirocco Base L4 - 1.6L 97ci 1588cc type EE - MFI.. I suspect these don't work with a 2.0 engine since there are in a 1.6
Installed currently: 0-437-502-015
http://www.oreillyauto.com/site/c/detail/BOS0/0437502015/02521.oap?year=1977&make=Volkswagen&model=Scirocco&vi=1285512&pt=C2368&ppt=C0024
John The Californian
PostPosted: Sat Jul 13, 2013 6:56 am    Post subject: Reply with quote
http://garage.ideola.com/prod-TuneUpKits.html
Ideola carries them for a decent price.
scm924s
PostPosted: Sat Jul 13, 2013 7:47 am    Post subject: Reply with quote
For an early car, with flexible braided fuel lines, the injectors should have a banjo fitting on the injector like these http://www.ebay.co.uk/itm/Early-Porsche-924-new-bosch-fuel-injectors-cis-k-jetronic-race-track-/171061747648?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APorsche%7CModel%3A924&hash=item27d4131fc0
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
ThomasJoseph315
Guest
PostPosted: Sat Jul 13, 2013 5:08 pm    Post subject: Reply with quote
This isn sorta my engine set up, I do not have the banjo style injectors. Not sure what that 5th injector is, maybe the cold air injector. But look at the lines and see how they go strait on the injectors? I think they did away with this style because of the lines breaking. I am very worried that I will break another fuel line when I replace these. Anyway I can get these loose without risking damage to the lines from the ends breaking off?
scm924s
PostPosted: Sat Jul 13, 2013 6:02 pm    Post subject: Reply with quote
It is possible your FI set up has been replaced with later pipes and injectors (unless the US spec is different from euro versions, which I doubt), shouldn't make any difference to running. The 5 th injector is a cold start assist, fires for a few seconds operated by a thermo time switch on start, worth checking to see if they leak rather than shut off when required. Removal of injector lines should be straightforward without damaging them.
Normally, early cars are not fitted with the solenoid (7) this was fitted to later cars to aid poor hot start issues, and was a retro fit as advised by Porsche to earlier models.
1977 Martini - sold
PostPosted: Sun Jul 14, 2013 12:53 am    Post subject: Reply with quote
If your injectors look like the ones in the diagram you pasted in, then someone has converted the system over using later model parts. Based on other things we've seen on your car (such as the custom/bastardized placement of the WUR), it seems quite likely that your entire CIS system has been cobbled together using an assortment of parts. This is going to make your job quite difficult in sorting out what you currently have, vs. what you should have in order for the car to run correctly.
There are two styles of injectors used on the normally aspirated cars. The early cars all had the banjo style injectors as indicated above, which is part number 047 133 551. These injectors are ~$60 each.
The later NA cars had the style of injector indicated by the diagram you referenced above. Those injectors are part number 049 133 551, and are ~$86 each.
(Incidentally, it appears I need to update the pricing on my website!).
This little exercise also debunks the commonly held belief that has been postulated on this forum that Porsche part numbers with different first tuplets are intechangeable so long as the last two tuplets are the same. Obviously, this is not the case with this particular part (and others that I have run across).
As for flow rate, there is an acceptable rate of flow, but I don't have that info handy, you will need to verify with your Haynes manual.
ThomasJoseph315
Guest
PostPosted: Sun Jul 14, 2013 12:39 pm    Post subject: Reply with quote
Anyone ever find a CIS injector flow rate chart?
What is the difference between 0-437-502-015 and 0-437-502-023?
ThomasJoseph315
Guest
PostPosted: Thu Jul 25, 2013 7:12 pm    Post subject: Reply with quote
I think I figured out what may be happening,.. 1980 fuel lines and injectors are installed on my car. Why? I think it's because the 1980 had more horse power,... so I am thinking larger injectors?
PostPosted: Fri Jul 26, 2013 1:17 am    Post subject: Reply with quote
No. The only difference is the way the fuel lines connect to the end of the injectors.
I skimmed the Haynes this morning, and could find nothing in there regarding flow rates. I don't know that any are published. But the injectors are not what control flow rates. It's the fuel distributor in conjunction with the WUR that control flow rates. The mechanical system is not going to be anywhere near precise in terms of flow anyway. There is often more than a 10% variance between brand new injectors, and there's not enough difference in the power level of the early vs. late NA models for it to make any difference whatsoever.
PostPosted: Fri Jul 26, 2013 2:03 am    Post subject: Reply with quote
According to this: http://www.connact.com/~kgross/FAQ/944faq02.html
The 1980 924 made 5 more HP than the 77 in the US.
The 76 actually made 125hp, but those are pretty rare.
Unfortunately to get a set of decent of injectors it sounds like you get to collect as many as you can have them flow tested to get 4 that are within a decent percentage of each other (I'd probably put the ones that run slightly richer in the 4 & 3 holes to help cool the warmer end of the motor)
Here's an interesting site about the CIS K-jet injection system, its Volvo centric, but it should provide a good overview of each subsystem: http://www.k-jet.org/
The best thing you can do is buy/build the proper CIS pressure testing tool and ensure your pressures are correct and that all four injectors are flowing within their normal range.
ThomasJoseph315
Guest
PostPosted: Fri Jul 26, 2013 2:39 am    Post subject: Reply with quote
Thanks for the tip on where to put better flowing ones.
Yea, the new name for this car "Frankenstein" I couldn't tell you how many mis-matched parts I have found on this thing.
I ordered some injectors from Germany through the dealer, I waited 10 days to find out there the wrong ones. I called O'reilly's and they had some at their local warehouse I could get at noon today that are the correct ones at almost half the cost.
On a side note, I found an interesting story about doing a V8 swap for like $1,000. Something about an LSt moter? Anyone got any good learning materiel on that?
