gegge
Posted: Tue Feb 05, 2013 6:51 pm Post subject: Tilton flywheel and clutch |
Ricardo aka RVJ informed me that there is a flywheel from Tilton. Anyone seen such? Any suggestions what kind of pressureplate and hydralic bearing to use?
Dreaming of a light streetfriendly 5,5" clutch that can stand at least 400Nm. _________________ Carl Fredrik Torkildsen
Raceboy
Posted: Tue Feb 05, 2013 7:44 pm Post subject: |
Having some experience on 2- and 3disc clutches (Tilton, Spec and some Chinese knock-offs), there is no such thing as "street friendly".
Yes, they are tolerable but there is no other option when you are in 600+hp territory but for 931 KEP aluminium 911 heavy-duty pressure plate + stock disc with Kevlar liners is a very good choice and it holds 500+ Nm.
Of course, it depends on the weight of the car also, the heavier the car, the more clamping force you need with the same torque figure. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
gegge
Posted: Tue Feb 05, 2013 8:50 pm Post subject: |
I am considering one cerametallic and one organic. Should be a lot easier to handle in traffic. No parking or citydriving.
Iīve got a HD 915 aluminuium pressure plate, but the next engineconcept requires some modifications. The starter need to be relocated for example; hence the 924 NA flywheel and an alternative clutchsolution.
Didnīt BassGT use aTilton? _________________ Carl Fredrik Torkildsen
Posted: Fri Feb 08, 2013 2:09 am Post subject: |
| gegge wrote: | | Didnīt BassGT use aTilton? |
No, AFAIK, he was using the 915 hybrid pressure plate setup with stock disc and early S2 flywheel. The Tilton stuff he was using was for the pedal assembly and braking system. _________________ erstwhile owner of just about every 924 variant ever made |
