AC removal
snakoil
PostPosted: Fri Jan 18, 2013 9:56 pm    Post subject: AC removal Reply with quote
Hi guys, I'm still in the process of AC removal
I got the heater core out of the car to clean and also remove the AC unit on passenger side of dash
Now I'm looking at putting it back but I realise the plastics pieces for central vents has a big hole intended to attach to the AC unit on passenger side.
How did you guys managed to connect central vents?
Is there another plastic piece that is intended for non AC 924?
Did you custom built this piece without the big oval hole?
Or did you simply put masking tape to block the hole(please don't answer that one)?
if you got pics it would be really appreciated
1979 924 NA
PostPosted: Sat Jan 19, 2013 12:06 am    Post subject: Reply with quote
I would just use duct tape. That is it's intended purpose, anyway, and it'll never be seen once the tubes are tucked away. Even if you found the right parts, duct tape will probably seal them up better anyway.
