924 2.0L N/A flywheel alignment
OliveRS
PostPosted: Mon May 04, 2015 7:13 pm    Post subject: 924 2.0L N/A flywheel alignment Reply with quote
Hello i'm a newbie in the 4cyl porsches, my dad just bought a 1980 2.0L N/A 924 .
I'm doing a few inspections on the car and find a weird thing .
Here is my question : is it possible that the flywheel was removed in the past and not right aligned ? is the distance between the fixing holes equidistant ?
i'm asking because i tried to check the ignition with a timing light, and i couldn't find the timing marks on the flywheel . the only mark i found was a painted dot that don't look like a factory mark . There is some marks on the flywheel ( -10 0 +10) but they don't match the "timing ignition" if i put my timing light .
Thanks .
PostPosted: Mon May 04, 2015 9:55 pm    Post subject: Reply with quote
Absolutely!
OliveRS
PostPosted: Tue May 05, 2015 12:14 am    Post subject: Reply with quote
Thank you .
So, to find the signification of this mark ( TDC or timing point) can i remove cylinder #1 spark plug and try to find the "real TDC" ?
The timing belt has been changed, so i suppose they rely on this mark to do it ?
I also have a question about the timing marks of the camshaft pulley, will post some pictures to explain . I have 2 differents marks : a Dot and a groove, don't know wich is the good one .
PostPosted: Tue May 05, 2015 12:42 am    Post subject: Reply with quote
Yes, you'll want to use the piston position via the spark plug hole to be absolutely sure of the crank position. Most likely you'll find the front pulley to be correct and align with the pointer on the oil pump. Most likely.
Unfortunately, of course, the front pulley isn't as precise as the flywheel mark.
For the cam pulley, you must use the mark on the backside of the cam pulley, not the front.
OliveRS
PostPosted: Tue May 05, 2015 4:03 am    Post subject: Reply with quote
here are the cam gear marks :
the dot :
in this cam position nothing match nothing (none of the dots on the pulley, marks on the flywheel) .
the "groove" :
in this position, the dot on the front pulley is near the oil pump point.
Looking through the valve cover filling hole, it seems that both valves of the #1 cylinder are closed . i think this is the "good" one .
In this position i can see this mark on the flywheel :
So if i'm thinking right the "pen mark" on the flywheel should be the TDC ?
thanks for watching .
PostPosted: Tue May 05, 2015 8:00 am    Post subject: Reply with quote
Yes- would definitely say the flywheel has been refitted out of align.
Would agree large mark and front fully are correct but makes timing difficult.
PostPosted: Tue May 05, 2015 9:46 am    Post subject: Reply with quote
Is it running? Well at all?
Your cam pulley dot should line up every other time the crank pulley notch lines up with the oil pump pointer, this is top dead center on compression stroke.
AFAIK both of those 2 pulleys are keyed to where you can't put them back together wrong.
You mentioned your cam dot doesn't line up with anything therefore your cam timing should be wrong.
It is non-interference so if this is the case your safe and it just needs to be reset.
Or maybe the cam pulley is on wrong too and they made the "groove" to correct it? IDK strange
80 Turbo - Slightly Modified
OliveRS
PostPosted: Tue May 05, 2015 4:09 pm    Post subject: Reply with quote
The car has troubles starting (cold, warm or hot) it looks like it floods very easily, but i can't say if it's the "common" starting problem due to the temperature sensor, or if it's due to a wrong cam timing . i will remove the timing belt cover, remove #1 spark plug to check the compression tdc and check the cam timing .
There is also some "kick back" randomly when cranking but not running (ignition advance?) .
PostPosted: Wed May 06, 2015 3:23 am    Post subject: Reply with quote
Rich H wrote:
both the cam and the oil pump pulley are keyed, there is no way you can get them wrong. The cam pulley has a woodruff key and the oil pump pulley had a notch that aligns it.
The cam pulley can be fitted backwards however. IITC the writing faces the back of the car.
As in the cam pulley can be put on the wrong way forward but not indexed incorrectly.
I have heard of instances where the crank pulley/oil pump pulley can shear off its key/notch and be easily misdiagnosed or overlooked, so unless its key/pin is physically broken it should be correct.
I agree with 924RACR as to you should manually check TDC on cylinder 1 with a dowel or something through the spark plug hole. That must coincide with the crank pulley notch to the oil pump pointer.
Shurick
PostPosted: Wed May 06, 2015 3:55 am    Post subject: Reply with quote
I use a strobe light with adjustable retard in situations like this. Mark the TDC position on a crank pulley or flywheel. If you need 10* BTDC for advance you just set strobe retard to 10* and aim for your TDC mark while adjusting ignition. Good strobe light with retard is not cheap though....
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
OliveRS
PostPosted: Wed May 06, 2015 4:08 am    Post subject: Reply with quote
thank you for those advices. I've got a timing light with advance button (first time with the 924 but i also have a racecar) . Will check all this this weekend, thank you .
OliveRS
PostPosted: Sun May 10, 2015 8:12 pm    Post subject: Reply with quote
Hello
Just did the "tdc check" throught the #1 sparkplug hole . the painted mark on the flywheel is the tdc, so i set the ignition advance to 10°btdc . Also checked the cam timing with the strobe light, looks ok .
Thank you for all your advices .
alan78924
PostPosted: Sun Jun 07, 2015 2:49 am    Post subject: Reply with quote
My flywheel has also been reassembled 180 deg out. Find TDC and use your own marks Or remove the engine and refit the flywheel correctly thats your only 2 options unfortunately
