difference 931 S1 and S2 cylinderhead ?
Dutch924-racer
PostPosted: Sun Dec 06, 2009 3:00 am    Post subject: difference 931 S1 and S2 cylinderhead ? Reply with quote
Is there any difference between the S1 and S2 931 cylinderhead ? So are they interchangeable ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Sun Dec 06, 2009 5:14 am    Post subject: Reply with quote
Was never in a situation to compare the two, but one minor item comes to mind. The later one might have the hole drilled for the turbo oiler breather, while the earlier one may not..? Easy to fix either way - either drill the hole/s, or install a block-off plate..
Other than that, I'm real sure they're the same and interchangable.
PostPosted: Sun Dec 06, 2009 5:41 am    Post subject: Reply with quote
Here's the shot of the Series I Euro head I have. Note the right side where there are two threaded holes. Not a block-off plate either.
PostPosted: Sun Dec 06, 2009 5:46 am    Post subject: Reply with quote
But then, on Spike, also a 1980, you can see there is the turbo breather.
PostPosted: Sun Dec 06, 2009 7:35 am    Post subject: Reply with quote
Many S1 heads were either already built with the breather update or may have been taken back to the dealer and fixed later. I have only seen one S1 931 head aside from Dave's photo above that did NOT have the breather update port drilled. Aside from that, I am not aware of any other differences between the S1 & S2 head.
PostPosted: Sun Dec 06, 2009 9:16 am    Post subject: Reply with quote
I have the "uppgraded" pipe to on my s1 motor (sits on the shellf at the moment in favour of a s2 engine). It also has the uppgraded manifold. Could it be that the late 1980s models got the uppgrades from factory?
PostPosted: Sun Dec 06, 2009 10:18 am    Post subject: Reply with quote
I think so. My two S1s are both in the 1400+ serial number range, and they both came with the update.
Rich H
PostPosted: Sun Dec 06, 2009 10:52 am    Post subject: Reply with quote
I'm sure I saw a leaflet issued to dealers to add the breather mod that included drilling the head
PostPosted: Sun Dec 06, 2009 11:00 am    Post subject: Reply with quote
More on the turbo breather updates here - http://www.924board.org/viewtopic.php?t=10536
jessy1984
PostPosted: Sun Dec 06, 2009 9:28 pm    Post subject: Reply with quote
they are both the same
just looked in pet same part number
only like mentiond here there's a modification for the turbo breather
if its not there just drill a hole in it
McGyver
PostPosted: Tue Dec 08, 2009 7:05 am    Post subject: Reply with quote
I don't have this breather update too in my 931' 79 cylinder head. But I have plan to drill that hole and use it later in my engine rebuild project.
Cylinder head part number is: 931 104 301 3R
It's taken from 924 Turbo series 1 - 1979
931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible)
moone924
PostPosted: Fri Dec 18, 2009 3:17 pm    Post subject: Reply with quote
I guess my late '82 931 has a early head on it, as it looks like the euro series one head Grenadiers has, with no breather.
Ryan Moone
New philosophy : one car project at a time.
PostPosted: Sat Dec 19, 2009 10:40 am    Post subject: Reply with quote
Spike has a series 1 US head.
Dutch924-racer
PostPosted: Sat Dec 19, 2009 6:06 pm    Post subject: Reply with quote
thanks for the replies, I just bought a s2 head. It does have the hole in it.
My other s2 had didn't have the hol in it. But I drilled it in myself and made the modification pipe.
937 trackday car
Series 2 engine
Fast road camshaft
pelican13
PostPosted: Mon Dec 21, 2009 2:19 am    Post subject: Reply with quote
I have an euro 931 of 1982 , CN100539 , there is no breather hole in the cyinderhead.
