924S LUMPY IDLE/ CAMBELT REPLACEMENT
andy
PostPosted: Thu Dec 20, 2012 4:45 pm    Post subject: 924S LUMPY IDLE/ CAMBELT REPLACEMENT Reply with quote
Hi all. My 1988 924S seems to be a bit lumpy/ surging on idle when cold, its not really bad but think it may start to get worse. Any ideas.
Also i should really change the cambelt. It was done in 2001 and had both belts and tensioner but has only covered 15,000 miles.
Does anyone have any good fitting instructions or a link as the Haynes manual is a load of S*?T.
scm924s
PostPosted: Thu Dec 20, 2012 6:39 pm    Post subject: Reply with quote
Lumpy idling is often the Idle Control Valve, situated in the most awkward place under the inlet manifold! Belts on the 924S/944 are everyone's nightmare, perceived wisdom is "if in doubt, change them". The 924 Haynes does not cover the S, you need the 944 manual also. Another excellent source is here http://www.clarks-garage.com/ shop manual.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
