Dean47
Posted: Sat Nov 03, 2012 12:56 pm Post subject: 1977 924 5 speed |
| I'm new to this so I hope I'm doing this right. I have 1977.5 924 that po installed 5 lug and 5 speed from 1981 turbo. The back off tranny is only 1/16 from gas tank. Is this right? Or did he do something wrong |
Horizonblue
Joined: 13 Oct 2011 Posts: 307 Location: Sorring city, Denmark, Europe
Posted: Mon Nov 05, 2012 4:38 pm Post subject: |
Turbo gearbox, isn't that always the "snail-tranny"?
Anyway, what you describe, is exactly the same as I experienced when I replaced the 4 speed, with a 5 speed 016 Audi gearbox on my 1976 car. There was close to no clearance between the gearbox and fuel tank.
I suspected that the gearbox would touch the tank now and then and cause a noise. So I took the gearbox off again and hammered a dent in the fuel tank, with a rod and a hammer. The rod was round in one end, so it didn't puncture the tank.
Did it 6 years ago, the tank is still not leaking, and nothing inside the tank (maybe rust) has come loose and clogged the fuel filter.
Anyway, the PO of your car has installed the gearbox correct. If you don't hear the gearbox banging against the fuel tank, don't do anything about it. _________________ Euro 924, 1976
"If you can't fix it, don't break it"
/P.G. Andersen |
Joined: 29 Jul 2001 Posts: 9075 Location: Royal Oak, MI, USA
Posted: Mon Nov 05, 2012 10:54 pm Post subject: |
Yep, no worries. Bit of a pain when you go to pull the trans, but otherwise, no issue. _________________ Vaughan Scott
Dean47
Posted: Tue Nov 06, 2012 11:00 am Post subject: |
| Thanks I been driving it without problems from tranny hitting gas tank just working out minor things since car was stored for 9 years |
!tom
Posted: Tue Nov 06, 2012 3:17 pm Post subject: |
| Horizonblue wrote: | | Turbo gearbox, isn't that always the "snail-tranny"?. |
Nope. _________________ 78 924 NA
5-lug |
