Mirror fell off ??
pw49
PostPosted: Tue Oct 02, 2012 1:10 am    Post subject: Mirror fell off ?? Reply with quote
1988 - 924S Driverside mirror fell off in the garage - not sure what is involved in this repair. If you can provide info I would appreciate it.
Thank you.
pw49
PostPosted: Tue Oct 02, 2012 6:42 am    Post subject: Reply with quote
The glass only, or the whole flag assembly?
pw49
PostPosted: Fri Oct 05, 2012 1:29 am    Post subject: Mirror fell off ?? Reply with quote
The whole assembly
staticsan
PostPosted: Fri Oct 05, 2012 12:28 pm    Post subject: Reply with quote
The internal part of the mount is on the inside of the doorskin with a small sub-frame with threaded holes. The motorised mirrors have a much more substantial mount than the non-motorised mirrors, but either way, it sounds like a screw gave way. It could be a stripped or worn thread or a rusted screw.
For access, you need to take the door card off and wind the window down. You should be able to then see what to do to fix it.
Wade.
'82 British NA - Which I think I've been very lucky with!
