dual turbos
Joined: 10 Sep 2012 Posts: 14 Location: Spring Grove IL
Posted: Mon Sep 24, 2012 7:33 am Post subject: 931 wiring harness removal? |
Any advice on the removal of the under dash wiring harness. I had some wiring with the insulation completely melted off the length of the wires (could be blower motor, since it wouldn't shut off), and it also damaged some nearby or adjacent wiring. So I thought removing the entrire harness would be easier than lying on my back trying to figure out which wires are good/bad. It looks like some of the wires go into the side of the fender area, wondered where those go? _________________ Dual Turbos |
Posted: Mon Sep 24, 2012 7:43 am Post subject: |
Be careful on pulling all the wires, getting them back thru the small holes with the rubber grommets looks daunting. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Harm
Posted: Wed Sep 26, 2012 3:52 am Post subject: Re: 931 wiring harness removal? |
| dual turbos wrote: | | …of the wires (could be blower motor, since it wouldn't shut off), and it also damaged… |
On the younger cars (±1980 and up) this is normal.
When the blower motor is switched off(-position) and the car is running (key in engine-on position), you will notice the van is stil rotating slowly.
Apparently it prevents gas fumes igniting the cabin during drives.
| dual turbos wrote: | | It looks like some of the wires go into the side of the fender area, wondered where those go? |
The ones I have seen there are;
– Antenna,
– Mirror/Windows control,
– Door/cabin light,
– Wires that go to the rear.
HTH
Regards, Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Wed Sep 26, 2012 7:10 am Post subject: Re: 931 wiring harness removal? |
| dual turbos wrote: | | Any advice on the removal of the under dash wiring harness..? |
Yeah... DON'T!
| dual turbos wrote: | | So I thought removing the entrire harness would be easier... |
It's not really possible to remove the entire wiring harness in one piece, without stripping the entire car. I know, I just did it.
It's probably possible to replace just the wires you need to. But, mate, you're gonna need to have the patience of a saint. I don't envy that task. _________________ '80 924 Turbo |
dual turbos
Posted: Wed Sep 26, 2012 9:40 am Post subject: |
I was planning on making it a winter project digging into the wiring, I think I need to tear apart most of the interior anyways to track down some miscellanous wires that I have know idea why there in the car, they don't look like they belong...I think one's to a kill switch and some others maybe bypass wiring? I'll keep you guys posted on the progress
Thanks _________________ Dual Turbos |
Posted: Wed Sep 26, 2012 9:56 am Post subject: |
On the upside, if you remove what needs to be removed for access, talking the entire wiring harness out in one piece is entirely possible. I have one as proof!
It's very time consuming and tedious. But ultimately not that difficult. _________________ '80 924 Turbo |
