jeffrey924
Posted: Mon Aug 06, 2012 7:47 am Post subject: please help with me my project car! |
whats up 924board? I am a new user to the site and also very new to the porsche realm.
I have been doing research for weeks now and feel like i have tried a lot, so know I turn to the experts.
as of right now I have two big issues that I cant seem to solve on my 1981 924 turbo 5 speed
1. I can not get power to my fuel pump! I tried jumping 30 to 87b and nothing but when I take my battery directly up to it i feel it turn on.
2. when my clutch pedal is depressed it stays on the floor till I pop it up, Im going to buy a master and slave but i have no idea how to bleed both.
something I should mention is that the car sat for 6 years untouched and I have been cleaning grounds like crazy. I have the car cranking over but not starting.
thank you,
Jeffrey |
Posted: Mon Aug 06, 2012 9:47 am Post subject: |
1). Did you check the grounds between the taillights in the rear? That's where the pump grounds and you can have weird issues. Also, did you bypass the pressure sensor in the intake? Read the 931 resurrection thread in the 931 section for more info on this.
2) buy/build a pressure bleeder and replace the parts. I would flush the brake fluid first, then do the clutch hydraulics. Make sure to bench bleed the master cylinder first and replace the hose from the reservoir to the clutch MC.
Hopefully the admin will move this to the 931 section as the 924S is a 944 in narrow guise and not a 924 turbo. _________________ Stefan
Posted: Tue Aug 07, 2012 4:10 am Post subject: |
Stop trying to fire the car until you have replaced the timing belt. _________________ Toofah King Bad
Posted: Tue Aug 07, 2012 4:27 am Post subject: |
| Rasta Monsta wrote: | | Stop trying to fire the car until you have replaced the timing belt. |
Oh, yeah. That ^ too.
Bent valves suck, plus you can fix the potentially leaking vacuum hoses that run behind the timing belt and replace the water pump. _________________ Stefan
jeffrey924
Posted: Tue Aug 07, 2012 9:03 am Post subject: |
i know the belt was replaced right before it was parked, it is on the list of things to do.
How do i go about bypassing the pressure sensor?
also where would you guys recommend i buy parts? |
Kens_74_911s
Joined: 01 Mar 2011 Posts: 529 Location: Southern Pines , North Carolina USA
Posted: Fri Sep 07, 2012 10:31 pm Post subject: tank |
Also pull the fuel tank exit line (the large fitting with strainer or primary pump). If the car sat that long its likely that you have a volume of thick tar like evaporated gas in the botom of the tank that will need to be cleaned before you sludge up the fuel pump. _________________ Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars |
Kens_74_911s
74 911s widebody
96 BMW 750iL
99 BMW 328i
