High oil pressure.
staticsan
PostPosted: Sat Sep 22, 2012 6:53 pm    Post subject: High oil pressure. Reply with quote
I've got a bit of a puzzle. For a little while some months ago, my oil pressure was showing at 0 - but the low pressure warning light was never on. With the help of a relative, we tested the gauge and it is working just fine. So I suspected the sender. I just couldn't arrange to replace it.
I don't know how long it was low, but not long afterwards, something changed and now the gauge is pinned. Again I suspected the sender, thinking the armature inside was sticking.
But now I see less than 10bar when starting, and sometimes it does fall to 8 whilst driving. Most of the time, though, the gauge is pinned hard.
What should I be doing? Is there a problem with the oil feeder tube? The oil has no bubbles in it, and is only slightly discoloured - last oil change was about 4,000 miles ago and it was 20W-60 mineral oil.
Wade.
'82 British NA - Which I think I've been very lucky with!
PostPosted: Sun Sep 23, 2012 5:56 am    Post subject: Reply with quote
IIRC thats what the gauge does when it or the sender is grounded. Check for a short to ground.
PostPosted: Mon Sep 24, 2012 12:28 am    Post subject: Reply with quote
The oil pressure sender controls both the low pressure light and the gauge, so the fact the low pressure light never comes on is a problem. It should always light when the ignition is turned on.
staticsan
PostPosted: Mon Oct 01, 2012 9:45 am    Post subject: Reply with quote
The light does come on under test. So that part is working!
I noticed the other day when running the gauge was showing 4.5bar! So the sender is clearly the culprit. I'll order a new one and figure out how to replace it when it turns up...
Wade.
pmcaya2
PostPosted: Mon Oct 01, 2012 12:04 pm    Post subject: Reply with quote
I had the same problem - the gauge pegged at maximum pressure while the oil light worked normally when key was turned to aux. The problem was a short to the sensor connecting wire. The connection is in a god-awful place near the fire wall. (the engine was designed as a transverse engine for front wheel drive cars, hence the bad location for the sensor).
Anyway, I suspect that the gauge and sensor are fine. I bought a new wire with a connector attached and spliced it to the old wire for a bit more wire to work with. One tool I found useful for the "operation" was a surgical clamp that I happened to have - it allowed me to clamp the wire and hold it in a tight spot. Hope that this helps. - Peter
