Shift linkage bushing
daniel
PostPosted: Fri Nov 09, 2012 4:06 pm    Post subject: Shift linkage bushing Reply with quote
Does anyone know of a cheaper source for this part:
http://www.ebay.com/itm/230777228366?item=230777228366&viewitem=&vxp=mtr
Thanks
1989 944 Cabriolet
PostPosted: Fri Nov 09, 2012 11:57 pm    Post subject: Reply with quote
Have you tried Porsche yet? These are common on 944s as well.
rockhound72
PostPosted: Sat Nov 10, 2012 12:18 am    Post subject: Reply with quote
I would check with Ed (www.thecouplingwhisperer.com) Sure you can get cheaper parts. How long do want to wait until you have to do it again? I just purchased shift lever bushings for my 924 from Ed last night. He already emailed and is shipping them today. Now, I paid $35 total, but they are made from the Delrin polymer and not plastic crap. I definitely don't want to keep changing them. I checked around and even if I bought the plastic ones, the shipping made it more than the polymers.
PostPosted: Sat Nov 10, 2012 2:28 am    Post subject: Reply with quote
The dealer? Pelican has them for $3.25, #999 924 002 40.
rockhound72
PostPosted: Sat Nov 10, 2012 2:32 am    Post subject: Reply with quote
Pelican sells plastic. I would want durability/quality personally.
PostPosted: Sat Nov 10, 2012 3:23 am    Post subject: Reply with quote
You do know that Ed doesn't carry that small bushing that fits in the shift lever, right? That is the one being discussed. Ed sells the rear "knuckle" bushings, which were available briefly in bronze as they are the same as some of the 914's and 911's. Ed's use Delrin (which is also a type of plastic I believe), which is okay, but Delrin tends to "cold flow", so I would be concerned that these would get sloppy overtime as the material is displaced, which is why they are used as cheap solutions for suspension bushings, but they have to be replaced fairly often. Polyurethane would be a better choice, imho, since Bronze is not available anymore.
daniel
PostPosted: Sat Nov 10, 2012 9:54 am    Post subject: Reply with quote
Thanks all, I grabed a set from Pelican.
1989 944 Cabriolet
leadfoot
PostPosted: Sat Nov 10, 2012 9:55 am    Post subject: Reply with quote
think I have two of these if you need them, let me check...
either that or I would suggest converting to an audi style linkage while you have the trans out, there's a how to done by ideola, and i've also done this mod using a slightly different.
I left the original bend at the shift end and have had no clearance issues, it also makes a nice adjustable short shifter design if you use a threaded bolt at the universal end. PM me if you want more details on this
stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Sat Nov 10, 2012 11:11 am    Post subject: Reply with quote
Rock, those bushes are hardly loaded. When I inspected mine (30 years old) they were fine. Are we talking about the same part, the four tiny guys at the lever?
Also, if you are referring to the rears, they are the same as 914 and come in poly from Weltmeister.
daniel
PostPosted: Sat Nov 10, 2012 11:20 am    Post subject: Reply with quote
bummer stu, I already ordered from pelican. I had to add oil filters and the like to justify the freight
Hopefully you might have some reverse gears for me though???
1989 944 Cabriolet
